Cat Hotrod
Cat Hotrod
Showing 1 to 10 of 12 results
timberbeast
Send a private message to timberbeast
Bet this guy works for cat
Sun, Aug 31, 2008 3:53 PM
Thank you received: 50
That's probably how much radiator it takes to keep that "flathead" cool😊 😊
Sun, Aug 31, 2008 10:59 PM
SJ
Send a private message to SJ
Looks about like an old D2 or D4 tractor radiator but would be pretty heavy with the cast iron frame (sides) on it.
Mon, Sep 1, 2008 6:27 AM
SJ
Looks about like an old D2 or D4 tractor radiator but would be pretty heavy with the cast iron frame (sides) and tanks on it.
Mon, Sep 1, 2008 6:29 AM
W. SMITH
Send a private message to W. SMITH
Reply to SJ:
The radiator on this hotrod looks like it came off a CAT TEN, FIFTEEN, or TWENTY. I never saw or believe they made a radiator for a D2 with the old wavy logo. It is an interesting idea for the hotrod 😊 W. SMITH
Mon, Sep 1, 2008 7:50 AM
tomseabee
Send a private message to tomseabee
Reply to W. SMITH:
Yep, looking at the elevated oblong filler hole and cap, I'd also guess 10, 15, 20?? Most of the ones I've seen had the model cast on the side castings. The bigger issue for me is how you see where you are going. Unless there is a hole in the roof and you are sitting on a bucket, how do you see past the engine, carb and radiator combination.
I guess you kinda got a idea where you were pointed before you got in the thing and just went from memory until you heard a bad noise.😮
Have a nice labor day holiday and pray for those in harms way on the gulf and east coast,
Tom
Mon, Sep 1, 2008 8:42 PM
SJ
Reply to tomseabee:
Tom
You are right it does look like a wavey cast name as my picture didn,t look too clear and I also didn,t look too close.
Mon, Sep 1, 2008 8:49 PM
Dozerman51
Reply to SJ:
It needs a "Hot Rodded" Cat engine behind the radiator to really make it look sharp.LOL😄
Mon, Sep 1, 2008 11:59 PM
naylorbros
Thank you received: 13
Reply to Dozerman51:
The Rad is off of a Cat Ten or small Fifteen. There are only four bolts across the top to hold the radiator guard. I do not know which tractor the guard is off of.
Ken
Tue, Sep 2, 2008 8:57 PM
SJ
Reply to naylorbros:
Ken
A Cat 3208 V-8 would look cute in it, more for show than go.I have seen the old flat head Ford V8 engines installed in the Ford farm tractors like the old Ford 8N tractors.
Tue, Sep 2, 2008 9:05 PM
ibrich
Send a private message to ibrich
Reply to SJ:
Not a Cat but this could be a lot of fun. A picture from the Tulare Tractor show a few years ago.
Wed, Sep 3, 2008 12:21 AM
