cat hose fittings
cat hose fittings
waukman
Send a private message to waukman
Has anyone done the homework to see what type of hose works good for the
3/4 fittings. I havn't had a chance to get to the Parker Store and look first
hand. It also does not appear that code 62 fittings will work with the Cat barb flange 5f2046
Tue, Oct 7, 2008 7:37 AM
Walt66A
Send a private message to Walt66A
I don't have my Cat hydraulic book with me, but I can tell you that many of the Cat split flange fittings do not cross to any industry standard, like code 62. It would probably be an XT3 fitting. It also takes a special press to assemble the hose and fittings.
Tue, Oct 7, 2008 7:57 AM
It's been a while since I checked but I believe its "code 61" fittings that will fit the 5f2046 flange.....regular 2-wire 3/4" hyd. hose works fine.
Tue, Oct 7, 2008 7:58 AM
catcrazy
Send a private message to catcrazy
I beleive that these are code 61 flanges and in the past I have taken the old flange halves ( the part the bolts go through ) & if you only have a flange on one end. You can crimp the code 61 flange fitting on one end & then slide the flange half over the sleeve, then crimp fitting on the other end.
Also I have been in some shops with old inventory & have seen some of these fittings but they are designed for 4 wire hose ( XT3 CAT hose ). So maybe contact your local CAT dealer & find out if they have any old inventory still kicking around
But if you still have all the fittings & sleeves any 2 wire braid hose will work for example: Parker 301-12. Good luck hosing if you have any more questions let me know.
Fri, Oct 24, 2008 11:04 AM
waukman
Reply to catcrazy:
Thanks all for the input. I found that Cat calls them "captive flanges" in thier
catalog. I ended up using Parker 302 hose due to one hose was made years
ago with parker series 30 reusable (which the two hole flange is no longer
available) I stayed with the the orginal cat two pieces on the others.
The partsman at Cat told me that Cat pricing was comparitive to Parker
but I did'nt compare specific prices. Nice to know for future reference.
Seems like fittings have a bullseye on them. I scraped a tree last year and
the knotted burr was a direct hit on a blade cylinder fitting. It snapped like
a tooth pick.
Sat, Oct 25, 2008 7:30 PM
catcrazy
Reply to waukman:
a tooth pick.
If you need some 3/4" two hole flange fittings let me know I may be able to help.
Tue, Oct 28, 2008 11:20 AM
Reddawgs
Send a private message to Reddawgs
Reply to catcrazy:
In Lincoln Nebraska is where I got some new ones for my little D2.
Tue, Oct 28, 2008 11:22 PM
MarkTrsst
Send a private message to MarkTrsst
for 3/4" lines, a standard 2-wire (SAE 100R2AT) hose works fine, and many shops also crimp Code-62 flange ends onto 4-wire (R12) if you need higher pressure. But your hunch about the Cat 5F2046 “barb flange” is right—Cat’s flange (“Super-Cat”) is dimensionally like Code-62 but thicker at the head (dimension C), so a straight Code-62 clamp/half often won’t seat correctly even though the bolt pattern matches. In practice you either use the Caterpillar-specific flange/clamp for 5F2046, or a supplier’s “Cat/Super-Cat” variant; some folks report Code-61 hardware mating to 5F2046 on older Cats as well. Bottom line: pick 3/4" hose spec for your pressure (2-wire or R12) and pair it with Cat/Super-Cat (or verified-compatible) flange halves rather than a generic Code-62 set.
Mark
Sun, Aug 24, 2025 2:59 PM
Thank you received: 55
use sae 100r2at hose with the cat reusable ends. the common size being dash 12 in other words 3/4 hose. (a dash is equal to 1/16th of a inch)
they are code 61 NOT code 62!
modern code 61 clamp flanges are 2 piece and 4 bolt instead of 2 bolt. keep the original flange plate and use new hose ends if required just remember to fit the clamping flange over the hose end before installing it to the hose.
the modern day cat code 61 fittings and flange plates as supplied currently by cat are thicker and need a spacer when using the vintage cat hose fittings and any other brand. i dont know when cat started using a thicker flange just that they do. or so my hydraulics service tells me. id say part of it is to allow higher working pressures modern day equipment has.
these old girls only worked at 1200psi part of why the cylinders are so large compared to the working capacity of the machine(more piston surface area means more working capacity for a given pressure.)
Thu, Sep 4, 2025 4:42 AM
