Cat Gen-sets
Cat Gen-sets
Pioneer1930
Send a private message to Pioneer1930
Anyone out there have or know where I could get some information on an older Cat gen set. I would like to buy one in the future but I kind of want to educate myself before I shop. As to common types, sizes etc. I'm sure a few folks out there know what to look for and what to shy from. Thanks in advance, I appriciate the collected experience of this board.
:hail:
Fri, Apr 1, 2011 1:42 AM
chriscokid
Fri, Apr 1, 2011 3:16 AM
terrywelch_archive
Reply to chriscokid:
check out the first 4 pages
http://s315.photobucket.com/albums/ll477/bacoly/foley%202/#!cpZZ3QQtppZZ28
Would you be interested in a 13000 Gen set. I know where one is coming up for sale. You can even buy the trailer it was to go in with the sides that open up.
Terry
Fri, Apr 1, 2011 5:06 AM
As with any generator purchase, getting the right voltage/phase capability and an appropriate size is of paramount importance.
Too large a set and you will likely have problems with 'wet stacking' especially with older designs that never run hard enough to build up enough heat to burn off built up carbon/unburned hydrocarbon liquids and vapors that escape combustion and condense in the cool exhaust system. You will want the generator to be loaded above 50% rated load most of the time with occasional loading to >80% full load for best performance.
What do you plan to do with the generator?
Fri, Apr 1, 2011 8:56 AM
Pioneer1930
I plan on using it for home / shop power. I was hoping for a 12 or 15 kw 4cylinder. To tell you the truth I was kind of wanting to get one with the same engine as my D2. (D3400) But i wasn't sure there was such a beast or what there ratings were. In the shop I run a Bridgeport, a Southbend lathe, plasma, arc, large wood planer, table saw, etc you get the picture. I don't want anything too large as noted by our fellow member it won't work enough to stay healthy but I also don't want it choking when I turn on the planer. My machine tools are three phase that currently have phase converters on them so three phase is not neccesary. Thanks for the help.
:grouphug:
Fri, Apr 1, 2011 9:18 PM
