Cat Fifteen idlers
Cat Fifteen idlers
Showing 1 to 6 of 6 results
Larry in phelan
Send a private message to Larry in phelan
Are 22 idlers the same as the ones used on a fifteen ? I need to replace an idler on a fifteen and my initial measurements indicate that a 22 idler will interchange .Wondering if there are issues with this. Thanks
Sun, May 24, 2015 11:29 PM
josh
Thank you received: 13
The short answer is yes, they are the same or similar enough. Depending on what serial number your 15 is and how much you are going to swap, there may be some small parts that need to be changed, if it is the complete assembly you are going to use there will be no issues.
Mon, May 25, 2015 2:40 AM
brewzer
Reply to josh:
I have a 22 Idler. - Wally
Mon, May 25, 2015 12:04 PM
Larry in phelan
Reply to brewzer:
Are the axles the same ? Hub width.? Wondering what small parts? I do have access to a 22 that has complete front idlers with the brackets.I just don't want it obvious that they are the wrong ones.
Mon, May 25, 2015 8:41 PM
josh
Reply to Larry in phelan:
If you are going to use the complete idlers with brackets from the 22, it should be a direct swap with no issues.
Tue, May 26, 2015 7:20 AM
Larry in phelan
Reply to josh:
Thanks Josh !
Wed, May 27, 2015 9:53 AM
Larry in phelan
Thanks Josh !
Wally, I sent a pm to you . Thanks
Wed, May 27, 2015 9:56 AM
