Cat engine progression
hfdzl
I have recently bought a D17000 gen set.
What is the engine series become after the D 17000? It became what? Next V8 series engines?  I have to admit I am not familiar with Cat engine designations.  Is there somewhere that you can find the lineageie; this series produced from  xxxx to xxxx?
Herb
Wed, Jul 14, 2021 5:09 PM
Thank you received: 50
As near as I can make out from my TRW Engine parts manual the next series 8 cylinder 5-3/4 bore engines would be D364 series 19B, 20B, 21B and the D375 series 16B, 17B, 18B, 43B and that seems to be the end of the 5-3/4 bore 8-cylinder engines. I don't have specific dates but I'd guess these would be 1960's engines.
Wed, Jul 14, 2021 11:23 PM
hfdzl
So that is the end of V8 engines? No newer series? Then everything then V12 and V16?
Thu, Jul 15, 2021 2:56 AM
Reply to hfdzl:
Not the end of the V8 cylinder, just the 5-3/4" bore versions.
Thu, Jul 15, 2021 3:30 AM
Thank you received: 63
It would be good though to see a progression history, of how products were superceded. For example, something I didn't know until recently is that the D8L was effectively superceded by the D9N in size, if not in nomenclature, as it was essentially the same tractor. On the other hand, I don't know if Cat would consider the current D2 model a supercession of the U-series D2 in the long term - probably not. If anything, maybe the D1 could be considered that, but I think they're so different in purpose and format, that it would be a stretch
Thu, Jul 15, 2021 5:00 AM
hfdzl
[quote] Not the end of the V8 cylinder, just the 5-3/4" bore versions.
OK, so what are the newer series?  Thanks, Herb
 [/quote]
Fri, Jul 16, 2021 2:52 PM
Wombat
Donor
Reply to hfdzl:
 [/quote]
had a dig around in a few books and came up with the following Cat V8 engines;
3208
3408
3508
D379
D346
1160
1150
1145
3150
3145
No doubt there are more than what I have listed here, as well there are many different configurations of those listed.
i hope this helps.
Wombat
Fri, Jul 16, 2021 4:24 PM
1951D2
Reply to Wombat:
3208
3408
3508
D379
D346
1160
1150
1145
3150
3145
i hope this helps.
Wombat
With the little research I have come up with the D17000 was produced between 1935 to 1955. There was a lot of variations with in its life both in the pony motor and the Main engine. The pony went from Timken main bearings to inserts, and the main engine went from six ring pistons to four. The six ring pistons are no longer available that I can find. Older main engine had two water pumps and later had One. Valve covers had a spacer between the head and the valve cover. When I overhauled mine I could still get the Valve cover gaskets ,head gaskets, Liners, rings for the six ring pistons, valves for the pony and main engine. Had to make my own pan gasket. and a lot of other stuff also.
These engines are a beast and have the coolest noise when running.
Sat, Jul 17, 2021 12:57 AM
hfdzl
Reply to 1951D2:
1951D2, Great info! Both engines are stuck right now. I will be getting it home next week. It has 2 waterpumps. Will start a list of the hard to get parts.
Thanks again, Herb
Sat, Jul 17, 2021 1:19 AM
