CAT dozer blade cylinder to fit Allis HD11?
Showing 1 to 7 of 7 results
Andrew_D
Send a private message to Andrew_D
The blade lift cylinders on my HD11 are shot. When I bought it, I knew the seals were pooched and the shafts were scratched badly (and deep!). Took them off and to the local hydraulic shop to be inspected. Says that the tubes are shot as well. He's figuring a price on making new ones, but I got to wondering..... Maybe there is something out there on another machine that would work?
5" Bore
36" Stroke
Trunnion Mount - Closed 26" pin-pin. Extended 62" pin-to-pin.
Does anyone know of a dozer with a similar spec cylinder?
Yes, I know that there are still other dimensions to consider: rod end attachment, trunnion design, hydraulic ports, etc. But those items "might" be relatively easy to adapt.....depending on the cylinder of course!
Any help appreciated!
Andrew
Fri, Jul 11, 2014 7:35 AM
Wombat
Donor
I had an HD11 series B, the lift cylinders on it were of similar size to the D8H 270 that I had at the same time, maybe an engineer can convert to length etc reasonably cheaply if you can get some from a wrecker.
Fri, Jul 11, 2014 9:47 AM
Andrew_D
Reply to Wombat:
Really? A D8H? Engine and weight wise, they were comparable in their day to the D6C. I was expecting someone to come up with a modern D5/D6 cylinder!
Andrew
Fri, Jul 11, 2014 10:49 AM
Mervyn Pepper
Send a private message to Mervyn Pepper
Reply to Andrew_D:
Andrew
Allis,s only operated around the 1500psi range; hence they had big rams and large gpm gear pumps to get the ram speed and power. I know for a fact HD11 rams are bigger than D6C/D rams. So you may well have to measure up some D7 or 8 rams
Fri, Jul 11, 2014 11:06 AM
mrsmackpaul
Reply to Mervyn Pepper:
yep that sounds about the way I remember
Fri, Jul 11, 2014 3:42 PM
Andrew_D
Reply to mrsmackpaul:
Yeah, the hydraulic system on this dozer was at 700-750psi before I tore into it. I haven't had a chance to fire it up yet now that it is together, but was hoping to get it over 1000psi, ideally 1200-1500psi.
Thanks for the suggestions! Is there a quick way to get dimension info on the D6/7/8 cylinders? Haven't had much luck with web searching so far...
Andrew
Sat, Jul 12, 2014 5:15 AM
mrsmackpaul
Reply to Andrew_D:
Andrew
I had a quick measure of some D7 E rams for you today 5" diameter and about 37" stroke hope this might help
Paul
Sun, Jul 13, 2014 6:23 PM
Andrew_D
Paul
[quote="mrsmackpaul"]I had a quick measure of some D7 E rams for you today 5" diameter and about 37" stroke hope this might help
Paul[/quote]
Thanks! Now, hopefully the trunnion mount is close enough to be workable! You don't happen to have a CAT part number for that cylinder do you?
Andrew
Mon, Jul 14, 2014 12:22 AM
