Cat Diesel 50.
Cat Diesel 50.
Showing 1 to 7 of 7 results
R W
Send a private message to R W
Anyone own a Cat Diesel 50, restored or in running condition.
Wed, May 9, 2007 1:56 PM
Thank you received: 93
Hi R W,
I know of one here in Melbourne, what do you need to know ?.
Thu, May 10, 2007 6:32 AM
R W
Reply to edb:
Hi R W,
Thanks Eddie, hope I may be able to get some pictures or see it one day, one
of these was the first bulldozer that I ever saw working, would have been about 1954.Knew where it was in 1976, went to the property to see if it was
still there in 2001, the owner said they dug a hole and buried it.
Regards,
R W
Sat, May 12, 2007 6:38 PM
Jim Sixty
Send a private message to Jim Sixty
Reply to R W:
Regards,
R W
Here is my Fifty diesel. Have had it running, but not what you can call running condition. It is a pretty long drive from you anyway.
Jim
Sat, May 12, 2007 7:35 PM
cdw
Send a private message to cdw
Reply to Jim Sixty:
Jim
I have one here in the us that I take to shows and pull my 66 grader with, runs exc. I will have it at the HCEA show in Connecticut in July hitched to the grader or what ever else I can pull.
Mon, May 14, 2007 8:00 AM
gwhdiesel75
Reply to cdw:
CDW, hope all is well with you. Have not chatted in quite a while. That Connecticut show ought to be really good.
Jim D4&6, really nice to see a Diesel Fifty posted on the bb. An impressive tractor to be sure.
GWH
Mon, May 14, 2007 8:39 PM
Thank you received: 77
Reply to gwhdiesel75:
GWH
When is the CT show?
Neil.
Fri, May 18, 2007 8:33 AM
gwhdiesel75
Neil.
Neil, you will find it under the stick post above "Spring National Pike" etc. GWH
Fri, May 18, 2007 7:31 PM
