Cat D9G Power?
Cat D9G Power?
Showing 1 to 10 of 69 results
gvanhouten
Send a private message to gvanhouten
Hi guys,
Was working the old girl yesterday on some iron pines that have a pretty good root ball system and it just seems that the old girl just does not have the pushing power she should.  I am thinking torque converter and or filters to check.  All fluids are great.  The engine is running very well but it seems that when I am up against a tree trying to push over the engine does not come up to full or half RPM.  When I was pushing before she was a beast now she is a bit wimpy... Any suggestions or do you believe I am on the right track?  Thanks guys hope everyone is well.  George
Sat, Mar 6, 2021 11:03 PM
Hello George, better to send us a video so we can hear what it is or is not doing.
Sun, Mar 7, 2021 4:26 AM
kittyman1
as Rome suggested, a video would be best....we like videos..
-since we're talking diesel power, my first wild guess would be fuel system....lack of fuel...fuel restriction of some type, lines, filter(s) etc...
Sun, Mar 7, 2021 5:14 AM
Thank you received: 78
Reply to kittyman1:
Birds built a nest in your intake?
Sun, Mar 7, 2021 6:44 AM
High idle rpm is 1455 +-30 rpm, 475 +-10 rpm, set decelerator at 700 +-50 rpm
I take it you already checked the rack and fuel pump lifter settings? If I remember that was an ordeal.
Fuel pressure good?
Check rpm at hour meter, that is half engine speed, or use a laser tach.
Sun, Mar 7, 2021 9:48 PM
Fuel pressure good?
Rome, is that decelerator setting the rpm that the engine should be at when the decelerator is fully depressed? In gear or neutral?
Sun, Mar 7, 2021 9:55 PM
Fully depressed, neutral.
Sun, Mar 7, 2021 10:10 PM
gvanhouten
I will be taking some video later today... Actually my wife will.... Yes, the rack was the first problem and then the rest.... Fuel pressure looks good starts right up... I am thinking maybe decelerator lever as engine just does not come to life with throttle fully open and decelerator engaged. When I lift my foot back engine does increase RPM of course in Forward 1 she moves and all just hard to get engine winding up. Thats why I thought torque converter first... I will take videos and post later today. Remember this is Hawaii so expect them tomorrow...
Sun, Mar 7, 2021 11:57 PM
Reply to gvanhouten:
Easy check would be that the decelerator really is releasing all the way and not holding back due to binding or interference. Does the engine go all the way to high idle in neutral? It can go to high idle but not be getting full fuel under load, which "usually" is because the rack is not opening all the way up under full load but it could also be intake restriction. If restricted, it would make black smoke (all the time, not just the rolling coal at acceleration : ). Could also be exhaust restriction.
Mon, Mar 8, 2021 1:11 AM
Wombat
Donor
How much oil in the converter case after shut down? There should not be much, if it is flooded it will act like a brake. This can be caused by converter failure, or scavenge pump failure or a blockage. Take a bucket underneath, you should only get about a gallon if all is ok.
best of luck, Wombat
Mon, Mar 8, 2021 7:16 AM
gvanhouten
Reply to Wombat:
Well bad day! Went out and after about 2-3 hours the dozer blew the head gasket between 1&2 cylinders. I was watching my new cat gauges and yes specked for the d9g and it was running a little more then middle of the green. I stopped and saw I believe on the compression stroke a puff of air fluid come out... Right on the edge so that would be #1 cylinder. My pressure relief valve which is new never blew either... The only thing I can think of is to take valve cover off and re-torque head... I never did it before if you remember there was an oil leak at the rocker to head and I replaced those gaskets... I am bumbed but hopeful a re-torque and hopefully that seals her back off. I will check the oil in the morning..
Mon, Mar 8, 2021 10:34 AM
