Cat D9D 18A
Cat D9D 18A
Showing 1 to 10 of 17 results
brian18a
Thank you received: 69
Started life working on Oroville Dam construction. Then Lundberg Farms in Richvale bought it and several and several others. They removed dozer, ccu belly pan to reduce weight and derated engine. Their Rice farming was basically D9 powered, until new fresh out of college farm manager said you cannot farm with these. Out of the 7 remaining D9s only mine and one other survived as running tractors. others scrap or smog.
Tue, Jun 16, 2026 8:27 PM
Thank you received: 288
There were 3 that went to BarNone Auction several years ago that were destined for scrap. Our friend Glen Ghilotti bought them plus the spare parts. His crew patched them back together, started them up and drove them onto the trailers. As far as I know, they are still part of his estate. Quite a piece of history you have there.
One of the Lundberg brothers used a Cadillac El Dorado for his farm vehicle. Quite a sight to see him with a dog in the front seat, and the trunk lid opened up hauling large items that belonged in a pickup truck or flatbed. Farming with class! JM
Wed, Jun 17, 2026 1:16 PM
1972RedNeck
Send a private message to 1972RedNeck
Do you know of any 18A parts machines? I would love to find a Cat no. 9 ripper for my 18A...
Mon, Jul 20, 2026 9:33 PM
brian18a
No, most D9 18a locally has Ateco rippers. Wasn't till the 66a D9g came out, that Cat rippers became popular
Tue, Jul 21, 2026 1:02 AM
1972RedNeck
Reply to brian18a:
I'd be okay with aftermarket if it bolted right on. Know of any that might be for sale?
Tue, Jul 21, 2026 2:33 PM
Thank you received: 62
Reply to 1972RedNeck:
I think you might be able to expand your search to other than Cat 18a machines. But then again maybe not.
As I know of ripper from a AC HD 16 bolting right up to early D7 E. So I suspect there is some commonality between brands. But after those thoughts the D9 was the big dog of its time. So would a ATECO ripper off TD 25 or HD 21 be big enough. But if you come across something else a tape measure would tell the story.
Tue, Jul 21, 2026 3:57 PM
brian18a
it appears that most D9 Ateco rippers pulled mounting studs out of case so are welded to case. My 19a is welded to case and ripper bent to point of being junk. A friend just bought a 18a with ateco welded to case, which might be for sale. But probable price and shipping would be prohibitive. I do not think D9 bolt pattern is compatible with other brands.
Tue, Jul 21, 2026 5:14 PM
72 RN, have you purchased any rippers so far? I recall you searching for some time here. JM
Tue, Jul 21, 2026 5:53 PM
1972RedNeck
I have not been able to find one yet.
Sun, Jul 26, 2026 5:04 AM
1972RedNeck
Reply to brian18a:
Shipping wouldn't be a problem as I could just come pick it up.
Sun, Jul 26, 2026 5:05 AM
naylorbros
Thank you received: 30
Here is an Ateco that is not welded to the case. I would bet you would need to buy the whole machine to get it. It has not been started in years but a couple a days ago i thought about taking a battery down and seeing if the starting engine would roll over.
Mon, Jul 27, 2026 12:38 AM
