Cat D8H 46A26253 Final drive service tool
Paul Sargent
Send a private message to Paul Sargent
Hi,
I am working on a Cat D8H serial number 46A25253 right hand final drive.  We need rent, buy, or barrow the following service tools 8B7548 bar, 2 each 8B7752 rods (replaced 5F7369), 8H684 ratchet, and 8B7560 steel plate (can probably fab this one?).  If anyone has a source or ideas, please share my email. [email protected] or cell is 304-389-9729.
Merry Christmas!!!!
Thank you,
Eric
Mon, Dec 13, 2021 12:19 AM
Paul Sargent
Thank you for your help...
Mon, Dec 13, 2021 12:20 AM
Thank you received: 35
Hi Eric,
the 8B7752 Legs/Studs are shown in the scan for General Pullers and are from memory OTC or similar brand.
The 8B7548 Bridge is shown on the above scan but not identified and also shown in the D8H FD Tools scan #5, figures #12 and #14.
The ratchet we had at the Dealer but never saw it used for the puller centre stud nut and thrust bearing--we used open end /ring wrenches.
Some Dealers will hire tools and some do not here in Australia.
Hope this helps others identify what you are after.
Mon, Dec 13, 2021 8:03 AM
another couple of scans of Cat General Purpose Pullers FYI.
Mon, Dec 13, 2021 8:17 AM
Wombat
Donor
Reply to edb:
When you get to adjusting outer bearing preload, don't bother making the adapter as pictured for D8H and D9G, just weld a 15/16" nut to the center of outer housing.
Regards, Wombat
Mon, Dec 13, 2021 8:47 AM
