Cat D8 w arm
Cat D8 w arm
Showing 1 to 10 of 10 results
catskinner
Has anybody ever seen anything like this? I know what it is for, how many of you know? I had never seen or heard of anything like this. This is another pic. from the building of Kanopolis Dam in KS. from Corps of Engr. pics. catskinner
Mon, Jan 22, 2007 9:15 AM
SJ
Send a private message to SJ
It looks like a giant metal detector, just kidding, as I have no idea what it is as I have never seen anything like it.
Mon, Jan 22, 2007 6:38 PM
Lou McMaster
Send a private message to Lou McMaster
Reply to SJ:
I have seen a similiar hook up for pulling 631B scrapers and 46A D8
under difficult conditions such as mud and water. I have also seen pictures of Super C Tournapulls being pulled with a 2U D8.
Mon, Jan 22, 2007 11:13 PM
Kelly
Reply to Lou McMaster:
Catskinner,
Lou has it right. That is what was known as “Snatch Cat”, in my neck of woods anyway. That one is a little more elaborated than what I have seen.
I think what history will show is they started using them with the Old Super C’s because of there weak goose neck. I have seen old pictures where there just used a cable and a labor to hook and unhook it, which I think later lead to what you have in the picture.
It appears they are stripping topsoil.
Kelly
Mon, Jan 22, 2007 11:45 PM
catskinner
Reply to Kelly:
Catskinner,
Kelly
Since I won't be able to get on here later tonight, I will give the answer now. Lou is right. It was used to pull turnapulls at the Kanopolis Dam in KS. It was also used with 3 other D8's to pull a Electric shovel from Langley, KS., the railhead, to the dam site. A distance of about 5-6 miles. I will post some more pics later on in the week.
Tue, Jan 23, 2007 5:44 AM
Delta Dirt
Send a private message to Delta Dirt
Reply to catskinner:
Have never seen anything even similar.
Don't quite understand the set up-----was this utilized as a cushion or "reflex" mechanism to allow the tractor to move forward pulling against the cushion of the springs and then the springs "reflex" and tend to multiply the pulling effect (maybe something similar to a spring shank chisel plow)??
Can somebody fill in some more details for the old dumb ass down here in the Delta.😕 😞
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Tue, Jan 23, 2007 7:38 AM
QuAD
Reply to Delta Dirt:
Delta Dirt
Here Some pics of something similar.
Sun, Jan 28, 2007 5:48 PM
QuAD
Reply to QuAD:
657 "Push-Pull"
Sun, Jan 28, 2007 5:52 PM
QuAD
Reply to QuAD:
657 "Push-Pull"
Photo Test
Sun, Jan 28, 2007 5:59 PM
QuAD
Reply to QuAD:
Photo Test
657 Push-Pul
Sun, Jan 28, 2007 6:01 PM
QuAD
Reply to QuAD:
657 Push-Pul
This where the first "Push-Pull" scrapers build by Kluck construction.
Sun, Jan 28, 2007 6:02 PM
