Hi Eric,
welcome to the BB.
Here are some scans of the 3 Stage Torque Converter Operation and Lube.
Hope they help.
Eddie B.![]()
Yes, the seals were designed to leak (fuel). The two drain lines were manifolded into one. Normal leakage is considered 0 - 10 drops a minute from either the front or rear seal. Higher leakage is normal when starting a cold plant. If the seal leakage is in excess of the ten drops it's time to replace the seals. Do not plug the seal drain tube. Doing so can force fuel into the lubrication system.
Hi Eric,
welcome to the BB.
Hope they help.
Eddie B.![]()
