Cat D8 Deep Plowing
Cat D8 Deep Plowing
Showing 1 to 6 of 6 results
Bumpus
Send a private message to Bumpus
[B]Meditator:
Opinions Are Like Belly Buttons. We All Have One.
You Got Yours, And I'll Give You Mine. Opinion That Is.
Because I Ain't Gonna Give You My Belly Button.[/B] 👋
Sun, Dec 27, 2015 4:05 AM
D6c10K
Send a private message to D6c10K
I'm sure there's a reason, but it looks like all the black dirt is now on the bottom and clay on top.
Sun, Dec 27, 2015 7:54 AM
Bumpus
Reply to D6c10K:
If this is being planted, they want to break up the hard pan dirt under top soil so future plants
will have deeper roots and water will go deeper in the ground and hold more water and not run off else ware.
Heavy farm tractors pack the ground down under to hard after a few years of use.
The top soil will still be there for deeper roots to feed off of.
Better plant growth.
[B]Meditator:
Sun, Dec 27, 2015 8:05 AM
Reply to Bumpus:
They do that a lot in Holland where they are reclaiming fields. There have been videos of it on here before. It is interesting to see how much horsepower it takes to plow that deep!
Sun, Dec 27, 2015 7:55 PM
oldtanker
Send a private message to oldtanker
Reply to Bumpus:
[quote="Bumpus"].
.[/quote]
You don't need to plow like that to break up hardpan. They make what's called a sub soiler that looks much like a ripper that allows multiple shanks to be pulled with a lot less HP. I have one for a Ford 8N tractor, single shank that runs about 18"deep. The ones for modern high HP tractors go deeper. Here is a link to one for less than 50HP compact tractors. http://www.northerntool.com/shop/tools/category_farm-acreage+3-point-category-1-implements+category-1-cultivators-tillers . Mine is about 60 years old so it's not even a new idea.
Rick
Sun, Dec 27, 2015 8:37 PM
Thank you received: 140
Reply to drujinin:
Hi, Drujinin.
I grant that it might take a fair bit of power to pull a single bottom plow that deep but I think the issue is more one of traction in that ground.
https://www.youtube.com/watch?v=YQ_DQYcD11w
Sun, Dec 27, 2015 8:39 PM
oldtanker
Hi, Drujinin.
[quote="Deas Plant."]Hi, Drujinin.
Just my 0.02.[/quote]
Well what did you expect with them using Fiat Allis instead of Cat?
Rick
Sun, Dec 27, 2015 11:08 PM
