cat d8 2u dry drive clutch adjustment?
DaChambers
Send a private message to DaChambers
I have a Cat d8 2u dozer. The drive clutch is slipping bad. It is a dry clutch. The lever pulls vary easy, to easy and it still locks in. All i see is the adjustment on the external rod, Don't see how that will tighten up the clutch.
Fri, Jul 4, 2014 6:11 AM
Old 3T lover
IT won't tighten the clutch. Remain calm, be patient, hopefully someone will be along any minute with a picture and an explanation.
That will be better and faster than me typing it out.
Fri, Jul 4, 2014 7:27 AM
Reply to Old 3T lover:
2U dry clutch adjustment....
Fri, Jul 4, 2014 7:42 AM
DaChambers
Thank you for the help.
Fri, Jul 4, 2014 8:25 AM
old-iron-habit
Reply to DaChambers:
Let is know how you made out. If still stuck I can take pictures of mine pointing out the procedure. I Just replaced the clutch in mine last summer.
Fri, Jul 4, 2014 11:38 PM
