Cat D8 1945 8R
Cat D8 1945 8R
Claney
Send a private message to Claney
What is the weight of this Cat. No blade no ccu just a drawbar and a homemade cab Gonna move this rig
next week. I have a parts book and an operators but neither have the weight
C u..........Claney
Sun, Dec 20, 2015 10:25 AM
Diesel Powered
Send a private message to Diesel Powered
17 tons plus the cab weight.
Sun, Dec 20, 2015 10:33 AM
Claney
Reply to Diesel Powered:
Thanks. I was thinking it was about that weight, but didn;t know for sure
Thank you................Claney
Sun, Dec 20, 2015 10:53 AM
Reply to Claney:
My info says 41,700 lbs for bare tractor.
Sun, Dec 20, 2015 1:44 PM
Claney
Oh WoW Old Magnet. I didn't know they were that much. A lot of iron. I'm sure the trucker will
like to hear this LOL. Probably have to reach a little deeper into me pocket.
Thank You
C u............Claney
Mon, Dec 21, 2015 11:11 AM
u-joint
Send a private message to u-joint
Reply to Claney:
Thank You
my info says 17 ton. the 8R that I have weighs 44000 with front CCU, angle blade, pans and rock guards and winch on rear.
Mon, Dec 21, 2015 12:11 PM
Reply to u-joint:
Does seem the source I was using is a little heavy. Closest I can verify by Parts Book info is for the 1H6852-1H9999 @ 34,000 lbs which should be the same for the 8R.
Mon, Dec 21, 2015 12:54 PM
u-joint
I think that's where I got my info from was the 1H. seems like the 2U and 13A was heavier but not sure why? not much different except transmissions. I think the 14A runs around the low 40000 pound mark.
Mon, Dec 21, 2015 12:58 PM
Thank you received: 40
Reply to u-joint:
Hi, Ujoint.
I don't know about the earlier 2Us up to the transmission change, but somewhere along the run they also went to the boxed-in frame instead of the 'webbed-in' angled steel frame and they also added the hardnose around 1950. Both of those changes would have added extra weight and I suspect that the 2-stick transmission would also have been heavier than the earlier slide bar transmission.
I would not be at all surprised if the 8R was a little heavier than the 1H too as Cat had a habit of finding weak points and beefing them up in later models.
Mon, Dec 21, 2015 2:37 PM
