Cat D7e winch leaking oil (see pic)
Showing 1 to 10 of 22 results
DrewAbt
Send a private message to DrewAbt
Hello Friends
 My military D7E has started leaking oil profusely from the front of the winch/back of tractor.
it runs down the tractor between the winch and the mounting plates of the cat.
i can’t see where it’s coming from but it comes out in multiple spots.
does this sound like the PTO shaft seal?  How hard is it to fix and are these seals still available?
thanks in advance.
Somewhere I read online that a blown hose inside the unit can force fluid out also but I’m not sure where.  I will take the covers off tomorrow and check that out,
This unit is a 1965 75E3 serial number military cat with relatively low hours 6-7k according to records.
 [attachment=76573]IMG_7002.jpeg[/attachment] [attachment=76572]IMG_7003.jpeg[/attachment] [attachment=76571]IMG_7004.jpeg[/attachment]
Sat, Jun 1, 2024 10:05 AM
bluox
The hyd. pump for the winch runs off the back of the flywheel housing so pull up the floorboards and check the hoses going to the winch.
Bob
Sun, Jun 2, 2024 4:18 AM
seiscat
Hello Drew, That's a very nice looking D7E. I can't be of any help on your Hyster D7H winch problem. I downloaded some of your pics so I could magnify them. I noticed that your picture of the underside showing the diagonal brace there was no sign of the dead-axle bearings being greased lately. I hope that I'm mistaken; please don't be offended, but those bearings should be greased every 10 hours of operation or very expensive damage will occur.
We have a lot of manuals and other info on D7Es in the ACMOC library, but you have to be a paying member to access them.
I found a Operation and Maintenance Instructions(OMI) on eBay:
https://www.ebay.com/itm/266345386272
This manual will save you time and money.
Craig
Sun, Jun 2, 2024 5:05 AM
DrewAbt
Reply to seiscat:
Craig
[quote="seiscat post=257204 userid=5422"]Hello Drew, That's a very nice looking D7E. I can't be of any help on your Hyster D7H winch problem. I downloaded some of your pics so I could magnify them. I noticed that your picture of the underside showing the diagonal brace there was no sign of the dead-axle bearings being greased lately. I hope that I'm mistaken; please don't be offended, but those bearings should be greased every 10 hours of operation or very expensive damage will occur.
Craig
That’s a good catch on that bushing needing grease.  I did just grease it before I used it but it should probably get some more.  I use this machine about 25 hours a year for the last 7 years that I have had it so it doesn’t get used a lot.  It’s pretty much in retirement out on my farm with just enough use to keep it strong.  I’ll call hyster on Monday and get some advice on that winch leaking…hope it’s not too bad to pull it off.
thanks again!
 [/quote]
Sun, Jun 2, 2024 10:27 AM
bluox
Reply to seiscat:
Craig
I get a kick out of home owners that want to go for the most expensive fix rather than checking the inexpensive easy stuff first..
Check the hyd hose that goes into the box on top of the winch, where the control cables go in .
Bob
Sun, Jun 2, 2024 9:37 PM
DrewAbt
Reply to bluox:
Bob
[quote="bluox post=257215 userid=2232"]I get a kick out of home owners that want to go for the most expensive fix rather than checking the inexpensive easy stuff first..
Bob
Im not a homeowner I’m a construction contractor doing millions of dollars of work every year.  I just dont specialize in antique bulldozers or their mechanical operations.  I OBVIOUSLY checked all the lines under the seat first.  It’s not leaking from any hoses unless they are internal and pumping it out the shaft seal somehow.
 [/quote]
Sun, Jun 2, 2024 9:44 PM
Reply to DrewAbt:
Bob
 [/quote]
Does seem like PTO shaft sealing would be the likely leak candidate or possibly one of the through bolt holes is missing cork seal.
https://www.alliedsystems.com/pdf/Winch/Manuals/599197W.pdf
Sun, Jun 2, 2024 10:24 PM
seiscat
Thanks OM, would you mind if I could see about adding this to our library?
Craig
Sun, Jun 2, 2024 10:37 PM
Reply to seiscat:
Craig
Anything on here is game for the Library.... Along with the Allied website for other winches.
Sun, Jun 2, 2024 11:40 PM
bluox
You know since you don't even know how the clutches on a PC winch works and apparently can't read a parts book we can lump you in the home owner class.
If the pinon seal leaks on that winch it passes oil into the tub on the tractor.
On the other hand when the oil supply hose leaks oil runs down the front of the winch.
Bob
Mon, Jun 3, 2024 1:05 AM
seiscat
Reply to bluox:
Bob
Hello Bob, ACMOC tries to help EVERYONE. We don't belittle ANYONE. If you think you are more knowledgeable and mechanically inclined than others, congratulations! Just keep it to yourself!
In my personal experience, someone who enjoys putting others down, suffers from low self esteem.
Craig
Mon, Jun 3, 2024 2:44 AM
