That cover and relief valve is used on many (not all) #46 Hydraulic Controls. Is there a number on the housing that might identify it as a Vickers Part?
Ebay says they have one.? Finditparts, Alcoa Tenn.
Thanks for reply mate ,, its seems to be cat , it has a cat casting # ,, and Cat found it in their parts computer ,, but discontinued !! ,, another friend near by ,, said it will more likely need the cartrage redone ,, he is going to look at it ,, he has redone #44 cartrages ,,, Thanks again ,,,, Cat parts e mailed the parts breakdown pic ,, we don't have a parts book .. Thanks again ,, will look at the ebay part too .. pete
Seems to be a few of them around...
https://www.machinerytrader.com/parts/construction-equipment/search?partnum=9F3840&pst=starts
Florin Tractor looks like a good source.
Has any body heard of new or recon cartrage for D7e #46?
Do any body have a #46 parts book ,, caterpillar ,, for D7E,,,, there mayb 2 types ,,, as some D6 U series also had #46 ,, but I guess lower volume apparently ,,, as I have a cat shop manual for it .. ...pete thanks
That would be for the #173 Hydraulic Control. S/n 48Cxxxx that uses a 100 gpm tank/pump similar to the D6 #46 and yes I have the parts book. If this is leading up to pump parts a s/n is required as there are two different pump groups utilizing three different cartridges. Cartridges are all Vickers and individual Vickers parts should have Vickers part numbers on them. Parts are still around (so far) but you have to have the Vickers numbers.
At one time I had the Cat to Vickers cartridge numbers but I can't seem to locate them. Cat should be able to help with that if you can identify by Cat number.
I have a service manual for the No. 173 hydraulic controls 48C1 - UP if info is needed.
Craig
I will get the Cartrage number next week ,,we have taken it out ,, its worn fairly bad ,, and the brass end plate is very badly worn ,, a parts guy here has another good one ... and will look at tidy up on the cartrage centre ... pete
