Cat D7 E track adjustor rebuilt but track continues to loosen
716thMP
Send a private message to 716thMP
I am looking for someone to give me suggestions on where to look for the problem. The bullet was rebuilt using genuine Cat parts by retired Cat tech; so I am confident that the seals were installed correctly. I hate to redo anything especially removing the adjustor. The adjustor was also replaced with new parts(grease fitting). Cylinder in the spring was cleaned and seemed okay.
Thank you for any help John [attachment=74232]92984E2A-C2AF-4FA1-ACC7-D02D9C56B8BB.jpeg[/attachment]
Tue, Nov 7, 2023 8:42 PM
That cylinder inside is most likely rusted and will tear out the new seals.
Tue, Nov 7, 2023 9:30 PM
gemdozer
Thank you received: 25
If your tracks are to worn the greace cylinder go to far and greace leak outside in spring
Tue, Nov 7, 2023 10:17 PM
seiscat
Reply to gemdozer:
I agree with Rome K/G, I think that is the is the most likely culprit. Sorry, it's probably time for a do-over.
Craig
Wed, Nov 8, 2023 2:06 AM
raz
Send a private message to raz
Reply to seiscat:
Craig
if the seal is in backward it will not hold
Thu, Nov 9, 2023 9:46 AM
