Cat d7 Cylinder rod trunnion
catmandoo
Send a private message to catmandoo
Hello everyone,
I am in the process of rebuilding a Cat hydraulic cylinder. Cylinder group number 7F2419. I ordered a new trunnion for the rod end (Part No. 5F117😎 and it did not come with the two half shells that suround it in the cylinder rod end. Mine are shot. Called Caterpillar and they have no idea what part no. would be. They are not shown in either one of my parts catalog for the No. 46 hydraulic control. The two halfs in my old cylinder rod are made of brass.
Anyone out there have any ideas? Please help.
Thank you
Steve
Fri, Dec 9, 2011 11:38 PM
Thank you received: 41
Looked through my various blade catalogs and don't see where any of them used a liner like you describe on the trunion end....just on the cylinder end.
Sat, Dec 10, 2011 12:07 AM
gemdozer
I am not sure but the# should be 2h6473 the same from the top cylinder
or 3j5689
Sat, Dec 10, 2011 12:25 AM
Reply to gemdozer:
or 3j5689
It is a bit confusing....does call out a need for two....but indicates cylinder end.....try the numbers gemdozer posted.
Sat, Dec 10, 2011 12:40 AM
catmandoo
Thank you all very much. My book calls out 6F5808. I will have to check to see if that is still correct.
Learn something every day. Hopefully.
Steve
Sat, Dec 10, 2011 1:15 AM
Reply to catmandoo:
Steve
The old 6F5808 # required four pieces and is replace by 2 of the numbers gemdozer gave (that's per cylinder).
Sat, Dec 10, 2011 1:26 AM
