Cat D7 3T17311 Attachments
Prospectorgav
Send a private message to Prospectorgav
Trying to get information on the blade fitted to my dozer for parts. I have the Cat form 8628 parts catalogue but it has no info on attachments. Old Magnet give me some info on the sheave blocks when I was chasing parts for them from a 7A & 7S book. Is this the same parts book for the blade? The push beam balls attached to the dozer were flogged out which I have welded up back to a size (Don't know original size) but have one fixed bearing cup on the push beams flogged out which I want to replace. The cup which unbolts has 6F2905 stamped on it. I searched the net and found a part number 4J3590 for the part in mention but went to Cat today and was quoted 6F2904 as the correct part. Are these the same part.
Tue, Nov 8, 2016 6:01 PM
Welding up that kind of joint seldom lasts long in actual productive use. Much better to spend your time welding new parts on.
Tue, Nov 8, 2016 7:15 PM
Thank you received: 74
Not sure if this applies in your case but sometimes the casting number is one digit different from the part number, so the part # Cat quoted might be the one you need. Old Magnet might know if there's a rhyme or reason behind that
Tue, Nov 8, 2016 7:27 PM
Thank you received: 61
Info is in the same 7A & 7S parts catalog.
Bearing is a 6F2904
Cap is a 6F2905
Trunion (ball) is a 3F4714
Casting numbers vs part numbers are usually off by the number of machining operations.
Wed, Nov 9, 2016 12:18 AM
