Cat D7 3T-4T crankshaft.
D74T
Send a private message to D74T
Could I please have some advice on the reliability of a crankshaft that has been rebuilt to standard/standard with hardchrome? It is a crankshaft from D7 3T part no 7B7452.
Thanks.
Tue, Jan 30, 2024 5:17 AM
Hard chrome plating the journals gives the ultimate in wear surface.
There are a few challenges to doing it right, adequate thickness, bonding and minimum voids (expect some). Can be a challenge to get someone to do the grinding to size.
Tue, Jan 30, 2024 8:33 AM
D74T
Thanks for that information, are there issues with hydrogen embrittlement causing the crankshaft to break in this application?
Cheers.
Tue, Jan 30, 2024 8:42 AM
Reply to D74T:
Cheers.
Yes, hydrogen embrittlement is inherent in the process but can be minimized with proper heat treating process.
Tue, Jan 30, 2024 10:05 AM
