Hello Robert! Its hard to tell on the picture angel but the seal is a 4J0522. Also when ordering parts for the hyd system you have to give the 173B model number and the 34H2672 serial number. You will have to drain the tank, remove filler cap to relieve air pressure then remove drain plug. Gary
Removed the blank end plate as shown in photo, did not see the o-ring seal. There appears to be a piston inside the hole. Is the o-ring seal on the piston? If so, how to remove piston?
Is the o-ring in the housing or face of housing?
Face-plate is machine cut to a flat surface. No o-ring seal inside that is visable.
Where other that caterpillar can I find a picture with parts list?
Would an after-market control valve be a option?
I'll get my parts book over at the shop and scan it for you. Looks like a plug with the o-ring on it under the cover, is there a threaded hole in the middle of it?![]()
Thanks for picture, that is what was needed to see how it is assembled.
I will update on progress hopefully next week.
Again, thanks for your help.
Your welcome.
Removed end plate to remove plug 4J4759 as shown on your drawing you sent (see above drawing Rome KG sent). Plug 4J4759 is no longer is cavity and I have no idea what happened to plug or where it could have gone.
Any thoughts or suggestion would be appreciated.
That must be why it's leaking then. IHM Used Parts in Ky shows having a new Cat one, 888-535-2817
