Cat d6c power shift
Cat d6c power shift
Showing 1 to 9 of 9 results
gordo
Send a private message to gordo
I have a cat d6c. Does anyone know if there is an adjustment for the power shift selector . It seems there isn't much travel between 1st and reverse. It's hard to find neutral. Any idea how to fix this. I appreciate the help. Thanks in advance.
Fri, Jul 8, 2016 11:27 PM
seiscat
Hello gordo, your shift symptoms are most likely caused by worn shift linkage. The spherical rod ends on the linkage are a good place to start. There are also bushings on the shift arm shafts that might be worn.
A service manual would save time and money; they are often available on ebay or in the For Sale/Wanted section here.
Fri, Jul 8, 2016 11:49 PM
Silver
Send a private message to Silver
Reply to seiscat:
I don't think it's always necessarily the linkage to blame? On my D6C the spacing between forward and reverse is fine when it's cold. As the transmission gets up to a good working temp I find neutral gets hard to find, as in when I shift out of first forward it pretty much goes straight into reverse. If I want neutral I have to wiggle it around a bit. But like I say, when it's cold it's perfectly normal. I've just been ignoring it for years 😊
Sat, Jul 9, 2016 8:24 AM
Wombat
Donor
Reply to Silver:
Gordo,
Its only worn linkages and adjustment, best to replace worn parts and get it working properly, as you have no modulation on your direction clutches and will damage the transmission going directly from forward to reverse. I have known as a very short term solution to adjust so that you do get neutral and possibly lockout 3rd gear as a result, I would only do this as an emergency until you get all the parts, link ends and control shafts, bushes and dust seals, these parts are not expensive, heaps cheaper than a transmission failure. Modulation is only by the speed clutches.
The Mad Mouth From The South (wear Velcro soled boots to stop falling off the earth):banplease:
Sat, Jul 9, 2016 2:57 PM
gordo
Reply to Wombat:
Gordo,
[quote="Wombat"]Gordo,
The Mad Mouth From The South (wear Velcro soled boots to stop falling off the earth):banplease:[/quote]
Thanks for the comments... Should I go to my local car dealer for the parts?
Sat, Jul 9, 2016 9:51 PM
Wombat
Donor
Reply to gordo:
Gordo,
I go to my local milkbar if I want a double malted milkshake, the parts you need I recommend you go to your local Caterpillar dealer.
Con mi amable respectos, Senor Wombat
Sun, Jul 10, 2016 7:30 AM
Thank you received: 57
Reply to Wombat:
Gordo,
Hi Gordo, yes your Cat dealer likely has the parts. I always try my Cat dealer first on the basis that if I buy from Cat, they'll see the movement in the stock and (hopefully) keep them in inventory
Sun, Jul 10, 2016 8:27 AM
tnc110
Send a private message to tnc110
Post deleted
Sat, Apr 21, 2018 8:59 PM
Thank you received: 39
Reply to Wombat:
Gordo,
That's not how I understand it.
Oil from the flow control valve goes to pressure control body. The pressure control valve is made up of two valves: modulation valve and pressure differential valve. The modulation valve prevents sudden clutch engagement. The pressure differential valve keeps a difference in the pressure between the speed clutch and direction clutch. Both valves work in combination to engage a speed clutch before a direction clutch is engaged. This arrangement provides for smooth engagement of the transmission and allows most of the load to be taken up by the direction clutches.
Sat, Apr 21, 2018 10:16 PM
tnc110
Reply to tnc110:
Post deleted
Post deleted
Sat, Apr 21, 2018 11:03 PM
