Cat d6 9u steering clutch bolts torque
Showing 1 to 10 of 22 results
mikewood869
Send a private message to mikewood869
Does anyone know what the bolt are torqued to on the bolts from the final drive and from the steering clutch to the rear end on a cat d6 9u or is it just feel tight?
Mon, Mar 7, 2022 10:54 PM
Standard grade 8 bolt torque.
Mon, Mar 7, 2022 11:22 PM
mikewood869
100 foot pounds?
Tue, Mar 8, 2022 1:20 AM
Reply to mikewood869:
100 foot pounds?
3/8" bolts 32+- ft lbs
1/2" bolts 75+-10 ft lbs
5/8" bolts 150+-20 ft lbs
Tue, Mar 8, 2022 2:10 AM
bruce oz
Thank you received: 21
 [attachment=67104]Capture.JPG[/attachment]
Tue, Mar 8, 2022 3:31 AM
Reply to bruce oz:
Pinion flange to steering clutch drum bolt torque?
Pinion bearing cage to case bolt torque?
Pinion to flange tons press fit?
Bull gear to to hub bolt torque?
Dead shaft nut torque?
Bearing/seal preload nut tightness?
Tue, Mar 8, 2022 4:49 AM
bernie
 fastenal.
[attachment=67107]Torque-Tension Chart for A307 Gr5 Gr8 Gr9.pdf[/attachment]
Tue, Mar 8, 2022 6:36 AM
mikewood869
Reply to bernie:
 fastenal.
I believe its the drum side and gear that have bolts that go in. The diagram that I'm looking at is on pg. 114. The article is D6 TRACTOR 9U13263-29764 FORM UE0032595 ue032595.
Tue, Mar 8, 2022 8:56 AM
bruce oz
 [attachment=67108]Capture.JPG[/attachment]
Tue, Mar 8, 2022 9:34 AM
Reply to bruce oz:
For 6B5063 bolts use the fine thread bolt torque then turn more if needed to bend the locks properly.
Tue, Mar 8, 2022 10:07 AM
kittyman1
-do you have a thread diameter?
- if it's 5/8" F, should be 18 threads per inch, Grade 8 is 180 pounds minimum lubed threads...
-so 150 plus the additional turn to bend locks sounds very close (as per Rome)
Tue, Mar 8, 2022 11:30 AM
