Cat d6 9u steering clutch assembly puller
mikewood869
Send a private message to mikewood869
We're pulling apart the left steering clutch on a Cat d6 9u. Does anyone happen to know what 8b7548 push puller looks like for a reference. Right now we have a 10 bottle jack on it. Or would it be easier to just find a shop to do it?
Wed, Jan 26, 2022 10:33 AM
bursitis
http://www.tractorparts.com/        http://steeringclutch.com/
try these fellas?
Wed, Jan 26, 2022 10:39 AM
josh
Thank you received: 7
Here you go.
Wed, Jan 26, 2022 12:17 PM
Thank you received: 27
Reply to josh:
Here you go.
I could wrong again, but my guess this is to take tapered splined shaft out of the center of clutch pack.
The last several I took apart I used a 40 ton press. I don't think it makes the whole 40 ton by the gauge on it. It is older so who knows, but needed a bit of heat once I had it set up in the press and put the pressure to it. Cats tapered splines are good to keep ware from happening to splines, but a real challenge to get apart without all the proper pushing and pulling gear. The old timer that use to do this work always took them to a friend with 100 ton press.
Wed, Jan 26, 2022 11:38 PM
mikewood869
Pretty much like this: [attachment=66490]IMG_3775.jpg[/attachment]
Thu, Jan 27, 2022 2:29 AM
mikewood869
Reply to mikewood869:
I ended up using the wrong puller number. The correct on is 7f9540 hydraulic puller. It’s on pg 125
Thu, Jan 27, 2022 4:04 AM
bursitis
https://www.youtube.com/watch?v=lR3zO_voYSY
a d4 but probably similar
Thu, Jan 27, 2022 5:13 AM
josh
7f9540 is a 30 ton, double acting, hollow hydraulic cylinder.
Thu, Jan 27, 2022 10:08 AM
mikewood869
Probably a little bit after I posted last, after talking to the steering clutch with a hammer and the jack, the thing came loose. All the pins are bent. Since we're in there, the throw out will be changed. One of the allens came out, but the other one needs to be drilled out. [attachment=66532]IMG_3779.jpg[/attachment]
Thu, Jan 27, 2022 10:09 AM
