Cat d5 96j shifting problem
Farm
Send a private message to Farm
My 96j doesn’t want to go in gear to change direction working sideways on a steep slope.
It’s worse when warm.
Going up and down slopes it sometimes hesitates going in gear to change direction.
I cleaned filter and replace transmission fluid 30 weight TO.
Fri, May 30, 2025 6:05 PM
Wombat
Donor
How much overfull have you got it, most of the older powershift Cats need to be overfilled for hillside work, I know D8's were 20 litres.
Regards, Wombat
Sat, May 31, 2025 6:32 AM
Farm
I have about half inch above full on my dip stick .
How much can I go over that mark?
Sat, May 31, 2025 6:43 PM
Wombat
Donor
Maybe try 1" to 1.5", see if that makes any difference, if not then we have another problem to solve.
Regards, Wombat
Sun, Jun 1, 2025 10:07 AM
Farm
Thank you I will try that.
Sun, Jun 1, 2025 11:34 AM
Farm
It does seem to help . Can I get it too full?
Do I need to to have it idle all the way down when shifting.
I never did get and real instructions to run this dozer.
Mon, Jun 2, 2025 2:29 PM
