Cat D4D SA oils
Cat D4D SA oils
wesley-sibley-9267
Send a private message to wesley-sibley-9267
I know this topic has been gone over a lot! But looking in my service manual the callout for d4d direct drive oil is sae30, I have Phillips 66 powerdrive 30 and that is the new T0-4 oil. I been running 80w-90 in the finals but want to switch to powerdrive 50. I do run it in the winter pushing snow, so should i run powerdrive 30 in trans or the 50? Also what oil for the clutch? Just stay with 30? Any help would be appreciated thanks!
Fri, Aug 28, 2026 2:53 AM
Thank you received: 59
Yes Cat at time was going But changed with the TO oil in the finals as well as transmission. Even suggesting that in older equipment. But changed their mind after a few years. So I would say for warm/hot weather the heavier oil in final's might be better. In your case talking of pushing snow, the lighter would seem better to me. But I am just a farmer, that ran whatever was cheap equipment over time.
Fri, Aug 28, 2026 3:13 PM
AnthonyF
Thank you received: 13
We have 50w in our clutch, operating in warm weather and it can drag a little until the oil is warmed up. I would think 30w would be better for you in the snow. For the finals I would want the most protection possible so I would think 50w or 80w-90 like you have would be fine too.
Wed, Sep 2, 2026 3:18 AM
