Cat D4D Questions
Cat D4D Questions
Showing 1 to 6 of 6 results
bulletpruf
Send a private message to bulletpruf
This D4D is for sale near me for $10k. It's in my price range, it's the right size, but I'm confused by the blade hydraulics with the smaller cylinders and hoses going over the tracks. Any thoughts on this machine?
Fri, Apr 24, 2026 12:40 PM
Thank you received: 140
Hi, bulletpruf.
Thatza toolbar dozer, made so that you can disconnect the 'dozer blade, swing the push arms around to the rear so that they become pull arms and attach a toolbar to them behind the tractor. They will do a lot of 'dozer work but they are not as good for heavy dozing work as a REAL 'dozer.
The genuine D4D 'dozer was the first D4 with the blade lift rams mounted on the hard nose instead of on the tracks.
Might be a good idea to get a serial number and post it here for verification 'coz I faintly suspect that you might be looking atta D4c machine - doesn't appear to have the genuine D4D hard nose - which may mean that it also has the INFAMOUS 'buzz bomb' pony motor, known for self-destructing.
Fri, Apr 24, 2026 12:55 PM
bulletpruf
Hi, bulletpruf.
Thanks for the quick response and the details. That's just the info that I was looking for.
Scott
Fri, Apr 24, 2026 1:08 PM
EZCAT
Thank you received: 23
Reply to bulletpruf:
Scott
That is a D4C
EZ
Fri, Apr 24, 2026 1:19 PM
That's Direct Electric Start, you can see the starter in the picture.
Fri, Apr 24, 2026 2:53 PM
Thank you received: 291
That is a D4C, not D. If you decide to inspect it, the first thing I have learned to do is check the water pump pulley. The "snout" is long and heavy and the bearings could be sloppy. Water pump rebuilds can get costly and parts tricky to source sometimes.
That is a toolbar blade as Deas mentioned, so if you decide to play farmer, you can flip it around and add attachments for tillage.
Not often those unique cabs are seen here in America.
Keep us posted. Thanks! JM
Fri, Apr 24, 2026 3:08 PM
Thank you received: 62
Now Deas. I was thinking you were really on top of the game, calling it out as an earlier model. Then you fall in the rat hole of the buzz bomb. The second picture clearly shows it has direct start, no buzz to go boom. ( wink, wink) Or it has already given someone else the pain of a boom, and they did the smart fix. Hopefully they had glow plugs put on it too.
I need to type faster.
All kidding aside with everyone focusing on the pony motor in that series oi tractor. I have no idea how much less tractor a D4 C is than a D4 D model. Coming from ag rather the dirt moving the clutch and standard shift is no a problem. Defiantly see the advantages of power shift for dirt work.
Fri, Apr 24, 2026 3:09 PM
