Cat D4D 88A series (as 78A) hydraulic group
Showing 1 to 10 of 13 results
Richard~J~W
Send a private message to Richard~J~W
The hydraulic group on my D4D has an I.D. tag of 54G843.......does anyone know which model it is?
Also what kind of hydraulic pressure and flow does it have.......it only runs the blade up/down, no other services fitted
Sat, Oct 14, 2023 2:44 AM
That would be a model 161 hyd control.
Sat, Oct 14, 2023 5:07 AM
bluox
If it has 1 valve it is a 141 ,or a  143 hyd. control. Don't know where the serial number break is.
main relief valve is around 1700 psi.
Pump output depends on which pump you have.
Bob
Sat, Oct 14, 2023 7:54 AM
Thank you received: 288
Reply to bluox:
Bob
141 single for D4, 142 two valves, and 143 triple valve. JM
Sat, Oct 14, 2023 9:26 PM
54G shows up as a 161 unit.
Sat, Oct 14, 2023 9:28 PM
[quote="Rome K/G post=251921 userid=1654"]54G shows up as a 161 unit.
***Not doubting you Rome: Sounds like someone swapped units on him. I have never looked in the bible to see what differences there are between all of those units, they all look the same to me. I should take notes of each tractor I have here and record the serial numbers for the chassis, engine, pump and blade for future reference. JM
 [/quote]
Sat, Oct 14, 2023 10:17 PM
bluox
A 141 or 143 hyd. control can be a 1 2 or 3 valve no such thing as a 142 .
Bob
Sun, Oct 15, 2023 1:02 AM
bluox
[quote]54G shows up as a 161 unit.[/quote]
A 54G hyd control can be a 141,143 151 or a 161.
A 161 would be on a D 6 tractor.
Bob
Sun, Oct 15, 2023 1:06 AM
Reply to bluox:
Bob
Time for me to hit the books, that is, where I put them last! Thx. JM
Sun, Oct 15, 2023 2:05 AM
bruce oz
Thank you received: 23
https://www.acmoc.org/bb/discussion-d72/5065-d4d-rehab-project?start=70#39314
Sun, Oct 15, 2023 2:35 AM
Reply to bluox:
Bob
[quote="bluox post=251925 userid=2232"]
Bob
Correct, the 54G's were made in the UK.[/quote]
[/quote]
Sun, Oct 15, 2023 2:41 AM
