Cat D4600
Cat D4600
Yoos Bros
Send a private message to Yoos Bros
I'm looking for an early D4600 engine like 1938-1940ish era. Does not need to be running but complete would be preferred. They were used in the early 12 graders, D5 9Ms and stationary applications.
Thanks, Josh  [attachment=69745]20221128_182135.jpg[/attachment] [attachment=69746]Screenshot_20221129-192017_Gallery.jpg[/attachment] [attachment=69747]Screenshot_20221129-192101_Gallery.jpg[/attachment] [attachment=69748]Screenshot_20221129-192047_Gallery.jpg[/attachment] [attachment=69748]Screenshot_20221129-192047_Gallery.jpg[/attachment] [attachment=69749]Screenshot_20221129-192137_Gallery.jpg[/attachment]
Wed, Nov 30, 2022 7:25 AM
Fat Dan
The D318 replaced the D4600. I have a 1945 9K No.12, Motor Grader D4600 and a 1954 8T No.12, Motor Grader D318. I believe I have read on the forum here, at least on the D318, that the crank is just a little bit different in the motor grader than other similar D318, engines. I don't know if the D4600 has the same trait with the crank, though I would at least ask around and keep an eye out. Just thought I'd give you a heads up.
My old 8T (AD UM) runs fairly well, I haven't had a chance to work on the 9K (Kay) yet. 🙄
Fri, Dec 2, 2022 5:04 PM
ned foley
Send a private message to ned foley
Reply to Fat Dan:
i believe there is a D4600 power unit for sale in MA. Take a look at FB marketplace
Tue, Jan 3, 2023 5:38 AM
Reply to ned foley:
Copy the address then paste here.
Tue, Jan 3, 2023 6:20 AM
ned foley
hopefully this works.
https://www.facebook.com/marketplace/item/847909866427687/?hoisted=false&ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp:65992d60-323b-4ebc-b851-c2d602eac7f4
Tue, Jan 3, 2023 6:54 AM
Thank you received: 49
Reply to ned foley:
It sure looks complete. That clutch and output pulley look valuable
Wed, Jan 4, 2023 4:55 AM
