Cat D4 U7 Pony Motor Problems Any Help Much Appreciated
Showing 1 to 10 of 10 results
Phil23
Send a private message to Phil23
Hi, I am having trouble getting my pony motor to rev up allow me to start the diesel. I have cleared out the fuel tank and carby, I have an electric start and the pony starts straight away. I have taken the air intake off to check the venturi and butterflies. The choke is off and the butterfly fully open and there is plently of fuel spraying into the intake. If I spray (areostart ether)into intake it makes no difference so I dont think it is a fuel problem. I dont know much about magneto ignition but only once did it fully rev up and it wont do it again it just revs a little. It seems to be getting good spark and I tried different leads and plugs but its still the same. I removed the distributer cap and cleaned the rotor button and cap (one of the carbons was a little damaged on one edge but should still work). I am going to borrow a cap to see if that helps, I"m just wondering if the magneto has points and a condensor maybe this is the reason why it wont rev up. Has it got advance mechamism that maybe is rusted up as it has been sitting in a shed for a number of years. If anyone can help that would be great. Thanks
Sun, Jun 30, 2013 8:13 AM
Governor problem. Reach across and see if you can push the governor arm which is connected to the throttle butterfly and get it to speed up.
If that's not part of the problem, have you drilled out any of the plugs and truely cleaned the carburetor passages? You can usually compensate somewhat if you run a lot of choke to help it pull enough fuel, but when it's right, its a dfferent "critter "!
Have you swapped the spark plugs for new? Wondering if it is firing on both cylinders?
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Sun, Jun 30, 2013 8:42 AM
Phil23
Thanks for your information. I did play with the govener arm and it didnt seem to make any difference.
I will pull apart the carby and drill out the plugs etc.
Do you know what the correct spark plugs are to suit this?
Is there a set of points in the magneto that may need cleaning?
It seems to be firing on both cyclinders as both spark plugs get hot.
It did rev out once for me but wouldnt do it again.
Thanks Phil
Sun, Jun 30, 2013 4:53 PM
gemdozer
Thank you received: 10
Reply to Phil23:
Thanks Phil
Like CCJERSEY said check your governor first
Sun, Jun 30, 2013 5:24 PM
Arthropod
Send a private message to Arthropod
Reply to gemdozer:
Recently one of my D2 ponies (same engine as yours) was not revving up. I checked all the usual suspects like the jet in the bottom of the carb bowl, spark plugs, mag firing. All that was fine. Governor hadn't changed. Finally I took loose the fuel line and found there was just a trickle of fuel coming out of the line at the carb. Tracing it back what I found was that the metal fuel line at its lowest point was almost totally clogged. I removed the metal line section between gas tank and shut off valve and used wire to rod it out real good. After that the pony started and ran like a top. And even better because I had cleaned the carb jet and did other maintenance stuff during all the trouble shooting.
But you say there is plenty of fuel. Just curious, did you remove the fuel line to the carb and verify fuel flow?
Yes, the mag has a condenser as well as points. And it has a coil.The condenser is just a capacitor there to help keep the points from arcing so much and burning up quicker. The condenser could dry out or short. But you have spark. The magnet in the magneto could be weak. Or, the coil generating the spark could be weak. I had a pony once that would start and run while cold and then not run once the pony was hot. Ended up being the coil in the magneto. It was breaking down when hot. If you have good blue spark, it kind of rules out the magneto. I might be wrong though, but it seems your problem should be a fuel issue.
Sun, Jun 30, 2013 5:39 PM
Reply to Arthropod:
I'm going to agree with Arthropod, reason is that if it has enough fuel to run, it will crank the main even if the throttle on the Pony is NOT wide open.
They take longer to start but do start.
This gives me the impression that you are lacking power???
You look down the carb with it running....said choke and throttle are wide open.
Seems to have good spark......I thought maybe Mag timing issue but that usually carries a whole other set of issues.
Basically this leaves Fuel delivery.
BTW, Have you noticed when changing around sparkplugs are they grey/white tipped or kind of sooty/black?
Sun, Jun 30, 2013 6:20 PM
Dozerman51
Reply to drujinin:
As far as spark plugs go, a lot of people on this site Including me say to go with NGK brand plugs. I Installed NGK 2910 plugs on my D2/3J pony back in 2007. They are still doing the job. If you have a later model D4/7U with the higher compression pony heads they might take a different plug number than the older pony heads. Remove, inspect and clean all pony fuel lines to make sure you have proper fuel flow to the pony carb. Good luck. I'm sure you will find the problem and be "Cattin" in no time.๐Ÿ‘
Joe Giraud
1940 Cat D2/3J#4103
1941 Dodge WC-12(Salad) Military 4x4
San Carlos, CA
Mon, Jul 1, 2013 1:00 AM
Soapy
Send a private message to Soapy
Reply to Dozerman51:
Joe Giraud
1940 Cat D2/3J#4103
San Carlos, CA
Look at the spark color. If it is yellow, you need a new condenser. Check the point gap while you have the cap off. .016 If you have a Bosch mag, remove the condenser, and carefully drill out the spot welds on the bracket, clean the bracket well, tin it with solder (acid core), and carefully solder it to a new condenser, (Napa p/n RR174) using as little heat as possible, with a small soldering iron. (like a Weller) Cool it immediately, to prevent interior damage. BTDT
Mon, Jul 1, 2013 1:50 AM
Reply to Soapy:
Hi Phil23,
maybe check that the throttle control rod tag is on the governor side of the throttle shaft lever pin of the carby.
If it is not it reverses the action of the throttle control rod and, from memory, can restrict the throttle shaft (butterfly plate) opening movement.
Mon, Jul 1, 2013 7:14 AM
Phil23
Reply to drujinin:
[quote="drujinin"]I'm going to agree with Arthropod, reason is that if it has enough fuel to run, it will crank the main even if the throttle on the Pony is NOT wide open.
BTW, Have you noticed when changing around sparkplugs are they grey/white tipped or kind of sooty/black?[/quote]
hi thanks for your advice,spark plugs are black,choke off,add ether and no differance,i will fit new plugs,clean out tank fuel lines and carb and try again,i will also check and clean points,16 thou,other than that im kinda lost.
Mon, Jul 1, 2013 6:25 PM
Reply to Phil23:
Sparkplugs are black, you are too RICH and possibly out of TIME!
You need to go back into the Carb and reset the float level making sure it shuts off the fuel flow.
Reset the Main and Idle speed screws.
Make sure you didn't install an incorrect/used gasket.
Then you need to find the Timing marks on the flywheel/crank, following that to the timing mark on the backside of the Magneto mount(?).
This will allow you to verify that the Mag is in time.
Then sort out the point gap issue.
Be sure the Cap, Wires and Plugs are all correct.
Ending with the proper gap on the Plugs.
Mon, Jul 1, 2013 6:59 PM
Newby Hall Tractor Fest
