Cat D4 serial numbers
Showing 1 to 6 of 6 results
MARTYN WILLIAMS
Can anyone tell me what numbers and the year for a D4 7J series machines? I would think early 1940's but not sure of the number sequence.
Many thanks
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Fri, Sep 5, 2008 12:48 AM
SJ
Send a private message to SJ
According to the Cat SNID book the 7J started production in 1939 and the 5T D4 in 1943 and then the 6U @ 7U in 1947.
Fri, Sep 5, 2008 2:01 AM
catsilver
Reply to SJ:
Between the 7J and 5T there were also the 2T series machines,7J 1939-1943, 2T 1943 to 1945, 5T 1945-1947. then they broke with traditionn and gave narrow and wide gauge separte serial numbers, narrow 6U series and wide gauge 7U series. 1947 to 1960? But I do know that the later D4C, 24A (UK built) started production in 1959!
Fri, Sep 5, 2008 3:52 AM
SJ
Reply to catsilver:
Catsilver, I think this Cat SNID sales book I got from the dealer is mixed up a lot. It shows as you said the 2T coming out in 1943 and also the 5T coming out in 1943 and the 5T RD4 coming out in 1945 both starting at 1 and up.
Fri, Sep 5, 2008 5:49 AM
gauntjoh
Librarian
Thank you received: 5
Reply to SJ:
Hi Martyn
Wendel's List show the following.....
1939.......7J1 - 7J1754
1940.......7J1755 - 7J4110
1941.......7J4120 - 7J7544
1942.......7J7545 - 7J9939
1943.......7J9940 -
I'm not sure what happened to 7J4111 - 7J 4119 probably a misprint.
I'm the proud owner of 7J2832W (W = Wide Gauge).
Fri, Sep 5, 2008 7:01 PM
MARTYN WILLIAMS
Reply to gauntjoh:
Hi Martyn
1943.......7J9940 -
Thanks everyone.When I go down to see the machine I will post pictures of it.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Fri, Sep 5, 2008 8:35 PM
ol Grump
Reply to MARTYN WILLIAMS:
Martyn
There's a pretty good listing of the various D2 & D4 models over on the ACME board that breaks 'em down to years and serial numbers.
Fri, Sep 5, 2008 9:06 PM
