Cat d4 7u smoking and popping louder now
Showing 1 to 10 of 38 results
kingmike
Send a private message to kingmike
Ok, so I've got another question about my 53 model d4 7u. When I bought it about a month ago, it would crank but smoked gray smoke at startup and while running except at full throttle. At full throttle the smoking would stop and seemed very smooth. Well after running it a little, it still smokes but I did notice that cracking the #2 injector would make it smooth out and no smoke. My book says to change out that injector nozzle to clear that up - I did. Seems harder to crank now, smokes probably more than it did, and pops a good bit even at full throttle. I didnt ever drain the fuel out and figure theres water in there but what's up with it smoking and making more racket now? I'm not a full blown mechanic and hope this is not a hard fix if anyone can help with advice? Thanks!
Wed, Jan 15, 2020 6:45 AM
If the #2 pump is not installed with the marked tooth of the plunger gear quadrant aligned properly with the line on the rack, you will get some obnoxious popping. It’s easy to check. Just take side cover off injection pump housing and look in with a bright light. You should be able to compare each pump to the others and quickly see if one is mis-timed.
Wed, Jan 15, 2020 7:01 AM
kingmike
I dont think the pumps have ever been changed on it but I'll check that. I'm just trying to figure how it got worse after I changed the nozzle. Perhaps that was already out of time and I made it worse by it actually getting fuel now. The old nozzle was rusted up badly!
Wed, Jan 15, 2020 7:32 AM
kracked1
Reply to kingmike:
Exhaust valve stuck open?
Wed, Jan 15, 2020 7:58 AM
kingmike
Reply to kracked1:
Could be I guess - how would I check that?
Wed, Jan 15, 2020 8:10 AM
kracked1
Reply to kingmike:
Pull valve cover and look at the #2 exhaust valve. Is it coming up the same height as the others? Is there any clearance between the rocker arm and valve stem when valve is closed? Listen for a hiss in the exhaust pipe while turning over by hand.
Wed, Jan 15, 2020 8:59 AM
kingmike
I took off the side cover and took a picture of the pumps. Does anything look wrong?
Tue, Jan 21, 2020 4:35 AM
Reply to kingmike:
Look underneath that sliding rail with the marks on it. The lines should match with the marks on the pump plunger gears. open the throttle then you can move it back and forth to check it, [engine off].
Tue, Jan 21, 2020 4:46 AM
kingmike
Ok. I took some more pictures. Looks like they are close?? Is the sliding rail supposed to move freely when the throttle is fully open? I didnt get it to move with my fingers but didnt apply a lot of force.
Tue, Jan 21, 2020 5:32 AM
Reply to kingmike:
Yes there timed ok. You can move the throttle towards idle but not shutoff position and it should move back and forth. Next would be to check or replace with new injection capsules. Are the rocker arm clearances ok? Head been reconditioned?
Tue, Jan 21, 2020 5:43 AM
kingmike
I only checked and replaced that #2 injector capsule. It was totally stopped up. Havent checked the others. My problem seems to be in #2 still but I didnt try to crank it today. Just way too cold. Anyway can any of that with the valves or rocker arms be checked without rotating the motor? I dont know how to rotate mine without using the starter. The pony isnt all hooked up and would take significant effort to get to run I would imagine. I did take off the valve cover but didnt touch anything today in there.
Tue, Jan 21, 2020 5:53 AM
| Kingaroy, Queensland
