What is involved in changing equalizer spring under engine?
Check out Aaron from LOAL on YouTube. He had a video of removing one from a 4G. Won’t be too much different i would guess.
Will do thanks!
Ancient Memories -- be sure to substantially block the engine in the raised position, there will be nothing to support it other than your cribbing. 2nd thing, be prepared for the weight of that spring assembly. GOOD LUCK, happy wrenching. Post pictures. cts
