Was the oil pump rebuilt or checked out? What weight engine oil are you running?
Hi Mark,
the scan below may explain what you are seeing that is NORMAL for these old Cats.
It also gives a clue as to the correct oil to use for these old technology engines that need old technology oils--as OM is alluding to.
They run on oil flow not pressure.
Eddie B.![]()
[quote="edb"]Hi Mark,
Eddie B.[/quote]
Eddie, I had no idea but when you think about it, that makes a lot of sense, thank you!!
I might order a couple of those $3,59 temp gauges. L.o.l.
