Cat D4 7U and Cat 12 318 starter part number
big harold
Send a private message to big harold
Hi all I have a Cat D4 7U and a Cat 12 318.
I havss converted the D4 to dirdct electric start.
And have been swapping starters between the dozer and grader.
I have found a 42 starter but the nose cone is wrong.
Does someone have the part numbef for the correct nosecone.
Mark
Tue, May 28, 2019 5:06 PM
nomorejohndeere
Send a private message to nomorejohndeere
Tue, May 28, 2019 8:37 PM
Reply to nomorejohndeere:
Dunno but what you need is probably in here
http://www.acmoc.org/bb/showthread.php?844-pony-to-electric-start-new-parts-source
Depends on whether you have a "type P" or "type S" lever housing.
Here's the parts lists for the various combinations.
Tue, May 28, 2019 11:26 PM
big harold
Thankyou.
That gives me all the information I will need.
Wed, May 29, 2019 1:20 AM
big harold
Reply to big harold:
Thankyou.
Well I have hit a brick wall once again.
All off the links I have tried are no longer valid.
Does anyone know where I can purchase a Drive end housing and Helix to fit a D4 7U.
Mark
Thu, Jun 13, 2019 8:54 AM
Mark
Seems sources are becoming harder to find...
Try here for both drive and drive housing (12 hole indexing if they have)
Oklahoma Starter Drive
Lexington, Oklahoma
1-800-336-0769
Let us know if your score.
Fri, Jun 14, 2019 4:13 AM
