CAT D4 7J info
CAT D4 7J info
MARTYN WILLIAMS
Hello there
Could someone tell me the measurments of a 7J,width, length and weight in working order?.A data sheet would be of great help.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Fri, Sep 12, 2008 4:23 PM
bruce oz
Thank you received: 19
hello MARTYN,without knowing what make of blade you have or weather it cable or hyd it is hard to give measurements .bruce oz
d47j tractor ,weight 10030 pounds
,length 10' 1 9/16''
,width 64''
blade could be(straight blade) 6' 10'' or (angle blade) 9'9'' wide ,added another 24'' to 30'' in length and blade could width another between 2,300 to 3,270 pounds ,
Fri, Sep 12, 2008 5:10 PM
MARTYN WILLIAMS
Reply to bruce oz:
,width 64''
Hello Bruce
I think it had a Birtley hydraulic blade.Will be seeing it on Sunday.Will post pictures.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sat, Sep 13, 2008 2:15 AM
bruce oz
Reply to MARTYN WILLIAMS:
Hello Bruce
Martyn
hello MARTYN ,is this the one your look at ,look good ,like the old cats for over there ,always look a bit green from sitting in the damp,bruce oz
[img]http://www.norwest-trading.co.uk/images/catd4_2lg.jpg[/img]
Sat, Sep 13, 2008 6:12 AM
MARTYN WILLIAMS
Reply to bruce oz:
Hello Bruce
Its im much better condition than that one if I remember ( first saw it 5 years ago).All it needs is the mag to sort out.Will take pictures tomorrow and keep you updated.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Sep 14, 2008 1:15 AM
MARTYN WILLIAMS
Hello Bruce
Martyn
Saw the D4 7j today,its a good machine with very few things to do on it.
One job that will need doing is the front idler.Has anyone drawings of the idler,there appears to be a spacer block missing between the frame and idler casting.Can anyone help?
The machine dates from 1942.
Many thanks
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Mon, Sep 15, 2008 2:25 AM
