Cat d4 30a question
Cat d4 30a question
Cat D2
Send a private message to Cat D2
Hello. Iam working on a friends D4 30a dozer and I was wondering if anyone can tell me how to check that the injection pump is in time with the main motor. I know on my D2 there is a measurment from the top machined surface of the pump, to the adjuster on the injection unit when you line up the timing marks. Would this be the same? Also how do I tell if the main clutch is a oil clutch or not? Would this unit have oil emersed steering clutches?
I believe this unit is the same as a d429a except that it was made in Aust.
Any help would be appreciated
Fri, Aug 22, 2008 5:59 PM
SJ
Send a private message to SJ
If the D4 has the D315 engine it,s fuel pumps are made the same as the D2 with the old D311 in it with the starting engine across the back.That setting is 1.736" for both the D4 with D315 engine and the D2 with the D311 engine.
Fri, Aug 22, 2008 7:35 PM
Reply to SJ:
D4 6U/7U is the same as the 29A/30A.
If it has an oil clutch there will be a dipstick and tube by the right brake pedal.
The steering clutches are dry.
Fri, Aug 22, 2008 11:23 PM
Cat D2
Thank you for your replies the infromation was very helpful
Sat, Aug 23, 2008 3:13 PM
