Cat D397 information
abrandt1980
Send a private message to abrandt1980
I am looking for information on Cat engines from the 1940s and 1950s that would have been used as engines for oil drilling rigs.
I have found that a likely model would have been the D397 (V-12, 500 hp @ 1,200 rpm). Other possibilities are the D364, D375, or D386.
Does anyone have technical specifications for the D397 engine? In particular, I am looking for hp and fuel consumption rate information, although general information about the engine would be useful.
Thanks for any help!
Thu, Aug 5, 2010 5:58 AM
bruce oz
Thank you received: 21
hello abrandt1980 ,spec sheet below ,bruce oz
spec sheet link
http://s315.photobucket.com/albums/ll477/bacoly/foley%202/
Thu, Aug 5, 2010 9:17 AM
KCB
Send a private message to KCB
Reply to bruce oz:
spec sheet link
abrandt1980: Here is a simple version of the line-up.
D364 (8-5.75x8.00) became D375 (8-5.75x8.00) became D379 (8-6.25x8.00)
D386 (12-5.75x8.00) became D397 (12-5.75x8.00) became D398 (12-6.25x8.00)
D399 (16-6.25x8.00)
There were various model suffixes (A,B,C,D) with different ratings over the 30 year period.
Thu, Aug 5, 2010 10:41 AM
abrandt1980
Reply to KCB:
D399 (16-6.25x8.00)
Thanks for the help! The spec sheets have more information than I could have reasonably expected to find.
Thu, Aug 5, 2010 9:14 PM
Thank you received: 22
Reply to abrandt1980:
Interesting starting system on the D397.....dual direct start starter motors at 32v, one starter on each side of the engine.
Fri, Aug 6, 2010 11:05 PM
