CAT D330 C Water pump Question
ms0115
Send a private message to ms0115
Cat D330 C Power unit for sawmill
Serial # 4B1888 Industrial
What is the difference in the water pumps on the D330 C Industrial vs a D330 in a piece of equipment? Having trouble coming up with a complete pump. Cat only offers a kit , aftermarket says not for industrial. Can anyone tell me other engines that the water pump would interchange with that would be easy to find? I am looking for a complete pump. Thanks for any assistance.
Wed, Feb 8, 2017 8:56 AM
The D330 uses a belt driven pump/fan combination. The D330C is a gear driven pump and the fan drive is separate. The D330C pump and 3304 pump are gear driven but not the same. Any D330C water pump should work on a D330C engine.
Wed, Feb 8, 2017 9:28 AM
ms0115
Thanks for the help again; Any ideas on a good aftermarket source?
Wed, Feb 8, 2017 9:46 AM
Reply to ms0115:
Do you have the part number for the pump you need?
Thu, Feb 9, 2017 5:37 AM
ms0115
Thanks for the help; I ordered on today.
Thu, Feb 9, 2017 8:24 AM
Reply to ms0115:
OK, what part number did you order?
Thu, Feb 9, 2017 8:35 AM
