CAT D318 Information
Daytonengines
Send a private message to Daytonengines
I have a CAT D318 power unit. The tag on the engine says 6V71. I am looking for information on what year this engine might be. I was told it was on a ship or boat as a bilge pump. Also where would I get parts to rebuild the water pump? Thank you.[attachment=48823]IMG_7207.jpg[/attachment][attachment=48825]IMG_7206.jpg[/attachment][attachment=48826]IMG_7223.jpg[/attachment][attachment=48824]IMG_7208.jpg[/attachment]
Thu, May 24, 2018 8:28 PM
old-iron-habit
We need a picture. Does not sound like a Cat D318. A Cat 318 is a inline 6 cylinder as used in the 9U series D6 and also for a number of years in the Model 12 grader. I wonder if you have a 6V-71 Detroit as they were common in the old construction tug boats we used. A 8V-71 has 318 HP. Is your engine a V6 and does it have 2 hand screws on top of each valve cover securing them down?
Thu, May 24, 2018 9:48 PM
brian18a
Thank you received: 62
Reply to old-iron-habit:
6V71 is a correct serial number for a marine D318.
Thu, May 24, 2018 9:55 PM
old-iron-habit
Reply to brian18a:
I'll be darned. I guess an old dog can learn something new every day. Thanks for enlightening both of us.
Thu, May 24, 2018 9:58 PM
ag-mike
we need pics anyway, if marine it should have reverse gear, if not.... maybe incomplete.
Thu, May 24, 2018 10:09 PM
Thank you received: 51
Reply to ag-mike:
If that Marine engine is set up for raw water/fresh water cooling, water pump parts may be difficult to find as the pumps are different than Industrial Engine, Tractor Engine applications. You will need to acquire the 6Vxxxx engine parts book. One source is ebay, there are some listed there. Service information for the D318, Marine and all others is to be found in the "Servicemen's Reference Book for the Diesel 4-1/2" bore 6 Cylinder Engine Form #30238-2
Thu, May 24, 2018 10:34 PM
Venson
Send a private message to Venson
Some aftermarket parts can still be available...Try to Google with part numbers.
Thu, May 24, 2018 10:43 PM
Daytonengines
This engine looks like any other D318 power unit. It has its own radiator for cooling. The air cleaner is definitely a marine air cleaner. There is no crankcase breather or oil fill where they usually are. The oil goes in one of the valve covers. It also has a hand operated oil pump to change the oil. This engine must have been down in a hole. I will try to get pictures tomorrow. We are going to use this power unit to operate a sawmill.
Fri, May 25, 2018 9:20 AM
Reply to Daytonengines:
Being a fan/radiator cooled engine, water pump parts should not be a problem to obtain. Either from Cat or possible after market sources.
Fri, May 25, 2018 9:25 AM
