CAT D2 oil pump , pan removal, bearings
Showing 1 to 10 of 21 results
IronworkerFXR
Send a private message to IronworkerFXR
Was wondeing how much is involved with getting the oil pan off a D2 and removing the oil pump, can I do the bearings in frame ? are they available if the crank is still good. I've done detroits in trucks liners too.
has stuck clutches too, so am I better off just looking for something else.
Thanks for the input
JC
Mon, Feb 18, 2013 11:53 AM
timbo1946
Send a private message to timbo1946
Everything is doable on the D2, but not always the easiest.
Been a while since I did mine, the rear of the tractor will have to be raised up about 6-8 inches. The equalizer spring will have to be loosened from both the track frames and the pan. The front of the tractor can then be raised so the equalizer can be dropped out from the pan. Then you can get the pan off to get to oil pump.
Main bearings are hard to come by, I had mine made. I worked with Foley Cat in Kansas, Mike in the parts area. I believe he got the drawings from Cat and then had them made at a local shop.
Steering clutches can be a pain, but there there a number of threads on this web site to how to go about it.
Tim
Mon, Feb 18, 2013 8:04 PM
If you are going to do this, I would simply remove the track frames and crib the tractor up or put on very secure stands, maybe shop fabricate something special for the purpose instead of having the tractor sitting steel on steel where you might shift it while torqueing bolts etc. Getting the track frames and tracks out of the way will simplify removing the equalizer spring and make access to the oil pan and crankshaft a lot easier. And they have to come off to pull the final drives. In many cases, the steering clutches can be broken loose by soaking with diesel and then puliing/pushing hard with the clutch levers tied or held back, BUT plenty of them have to be disassembled. All the disks and the brake drum, springs etc are available new aftermarket to repair the steering clutches if you need.
Many times what happens is the steel disks corrode and swell the clutch pack so much that the springs are fully compressed and no amount of pulling on the levers can compress them further to release the pack. Some have sanded the steels and the friction disks down to remove the rust and reassembled, but the new metalic frictions available from General Gear should make this job a once in a lifetime repair. The old organic linings may stick again if you don't use your tractor regularly.
On the other hand if you want to do this in stages, you could even work on the engine through the inspection covers on the side to drop some caps and plastigauge the crankshaft and bearings before you tear into it for real. If you cannot find bearings, I believe the old bearings can be re-babbeted instead of fabricated from scratch. Seems like the guy that does that has posted on here in the past. I went through all kind of grief trying to find a thrust bearing I needed for a D333 and ended up modifying the thrust bearing system of the engine to accept new style half circle thrust bearings and only a few months later found out I could have sent my old one piece thrust bearing to be rebabbeted😖mokin:
Tue, Feb 19, 2013 2:07 AM
Thank you received: 78
Ironworker, if you're looking at that D2 in Harvard MA, then I'd also be wary of more than just the oil pump having shorn its drive (I'd be curious how the owner verified that..) But more importantly how long it ran without pressure. They can run for a fair while but you'll never know until you've either got it going or you pull it apart. Best of luck - I was looking at it but decided not to (for that price at least...)
Tue, Feb 19, 2013 9:33 AM
[quote="Neil"]Ironworker, if you're looking at that D2 in Harvard MA, then I'd also be wary of more than just the oil pump having shorn its drive (I'd be curious how the owner verified that..) But more importantly how long it ran without pressure. They can run for a fair while but you'll never know until you've either got it going or you pull it apart. Best of luck - I was looking at it but decided not to (for that price at least...)
Neil[/quote]
I got an email from the owner and he is looking to get $2500 FOR IT.
Tue, Feb 19, 2013 11:27 AM
IronworkerFXR
Reply to dpendzic:
Neil[/quote]
sort of why I shyed away from it, saw a real nice running with like new bottom for 6k with new cluthes too. I'd be there in expences in no time .
Wed, Feb 20, 2013 1:09 AM
Reply to IronworkerFXR:
Well, that's a bit cheaper than it's been on eBay at $3500. One might be interested at that price but it's still like a box of chocolates... I dunno, if it keeps getting cheaper, at some point I'll be interested : )
Neil.
Wed, Feb 20, 2013 8:47 AM
Arthropod
Send a private message to Arthropod
Neil.
IronworkerFXR, you PM'ed me about the clutch pics and pump.
Are you talking about the steering clutch pictures I posted back in 2011? I see they are still on the site. Hopefully they are helpful. I haven't been on the site in a while, but just happen to log in the other day and also noticed that CAT for sale. I have removed an oil pump before. Actually cribbed up the D2 and got the oil pan off. The time I took off the oil pan was to change the whole pan, due to a cracked pan. I wasn't taking the oil pump out at the time. But the same labor to get to the oil pump. It isn't all that bad. I did also remove the track frames because I was doing swaps of those and installing better rails, etc. I don't have experience regarding a shear breaking in an oil pump. I guess as another member said, the concern is how long the machine ran with no oil pressure. The old machines are very tough and can take a lot of abuse, but no oil pressure is bad. But, I've heard of other guys with similar problems, like the oil line to the oil cooler breaking and all the oil running out and they not noticing it right away. And their machine still is fine after repairing and replenishing the oil. Probably the only way you will know of damage would be to do as already said below... remove the pan, remove the bearing caps and examine the bearings. At that time you could plastigage to see how much clearance was there, plus look for bearing scoring, burning, etc.
Regarding the clutch pack.....I have had good luck and bad. I have removed about 8 D2 steering clutches over the years and only broke one brake drum. Maybe I was just lucky. What happens is, worse case, the teeth on the clutch pack get rusted to the splines in the drum and as you are prying off the final drive, the teeth are not slipping out of the drum and instead are PULLING the drum until it shatters. The one I had break, it was almost like welded to the clutch pack with rust. I had to actually use a hammer and chisel and crack the remainder of the drum off the pack. The pack was worthless too. The drum is cast metal, so it will crack if you whack it. If you are lucky you can squirt some lube (kroil, liquid wrench, or automatic trans fluid which is a solvent) into the splines, let it sit for a while (days), then attempt to remove the final. If you take off the cover on top the trans (where you adjust the steering clutches) you can look through openings and see the brake drum splines...where the clutch is slipped into the drum. You could use a long tube and pour some lube all over those splines (which I do), trying to work it into the drum so that the clutch teeth might slip free on final removal.
It has been a while since on this site, but I know that some company was manufacturing aftermarket D2 drums. I have four D2 drums from my parts machines I've been saving. I could maybe part with one if the price was right.
You will laugh at the crib job I did on this D2. Was many years ago before I had a concrete floor to work on. Looks crazy, but it was actually very stable.
Wed, Feb 20, 2013 9:40 PM
Inter674
Reply to Arthropod:
You will laugh at the crib job I did on this D2. Was many years ago before I had a concrete floor to work on. Looks crazy, but it was actually very stable.[/QUOTE]
So when were you in my workshop taking pictures??
Note: I must improve my security systems😊
Thu, Feb 21, 2013 6:00 AM
IronworkerFXR
Reply to Inter674:
thanks Arthropod,
I have worked on unfortunatly on several motors where there was a oil starvation problem, RPMs , load, duration, all play into the damage amount. low speed I see a lot of bearing galling and transfer,high speed scored cranks spun bearings ,
your pictures are a real help to us who have not preformed the tasks, and I always take somebodys thoughts into how I'd do it . the cribbing is interesting , been there done that too.
Thu, Feb 21, 2013 11:47 AM
Jack
thanks Arthropod,
About four years ago I was looking for a set of mains and rods bearings and having very little luck for quite a while. I checked out a couple of shops that claimed they could rebabbit Cat bearing shells. Turned out that they were talking about later engines.
The D2 used a thick solid aluminum alloy bearing material and used no steel backing. When you pose that fact to them, they say, "Whoops, never did any of those!"
If you must machine new bearings from scratch, you need to make steel shells and they need to be something like 3/8 " thick material, top and bottom half DOWELED together in pairs, oil land clear around at he middle, and the cap half bored for a dowell in the cap to keep them from spinning. (They did this so that bearings could be turned out in the event of an inframe overhaul.) Such steel shells could be babbitted. I suppose that's what Timbo did. He rebuilt a D2 engine about the same time I did mine.
The Cat aluminum bearings are a pretty hard material for a bearing on a steel shaft. Cat solved the problem of possible galling by installing a huge oil pump. It moves as much oil as a lot of tractor hydraulic pumps. The idea is to have enough oil in the bearing to keep it from actually touching the shaft. The construction is bullet proof normally, but when you run it out of oil, the damage is severe and it doesn't take long.
This is just my observation. By now there may be other options. Personally, I'd weigh the Cat in question and offer scrap price minus enough to make scrap/salvage worthwhile. Then I'd check into to it in depth, like tear it all apart like I was going to rebuild or sell pieces. Whatever you do, be careful and good luck.
Jack
Thu, Feb 21, 2013 12:32 PM
