Cat D2 Identification
Showing 1 to 10 of 22 results
Hiranger
Send a private message to Hiranger
Hi all,
This is my first post to start learning aboutthe D2 Cat. I'm looking at one to buy, it has serial number 5U-15692. I can't seem to locate anything online that helps me know what year it is.
I'm guessing '1953, but it could be newer. The 5U is the wide track with 16" tracks, 5-rollers, solid front idler, looks to have a #41 hydraulic pump behind the brush guard, PTO in the rear over the draw bar, not sure what kind of dozer blade this is? Also- I'm unsure about the clutch, is it a wet or dry one? Is there a serial number cutoff to help determine?
I assume it is the 311 diesel engine, with the gas pony motor. Not sure if its electric or not.
Any help is much apprecited, thanks! [attachment=67376]IMG_1681.jpeg[/attachment][attachment=67377]IMG_1680.jpeg[/attachment][attachment=67378]IMG_1679.jpeg[/attachment][attachment=67379]IMG_1678.jpeg[/attachment][attachment=67380]IMG_1682.jpeg[/attachment] [attachment=67376]IMG_1681.jpeg[/attachment][attachment=67377]IMG_1680.jpeg[/attachment][attachment=67378]IMG_1679.jpeg[/attachment][attachment=67379]IMG_1678.jpeg[/attachment][attachment=67380]IMG_1682.jpeg[/attachment]
Wed, Apr 13, 2022 5:04 AM
gauntjoh
Librarian
Thank you received: 5
Welcome Justin,
You should take a look at our new "Machine Page" which will give you some of the information you need. Follow link below or select the yellow "Machines" box at the top right hand of the forum page.
The Cat D2 - Antique Caterpillar Machinery Owners Club (acmoc.org)
5U 15692 was made in 1955. On the left fender is the battery box for the electric pony start. It looks to be a very nice tidy tractor. It is difficult to see from the pictures you posted, but a key question is the state (degree of wear) of the "running gear", i.e. track chains, pins and bushes, sprockets, idlers and rollers.
I'm sure others will be able to tell you if the machine has a dry or an oil clutch and the make and type of blade
I would also encourage you to join our club (from just $40 p.a.) as you will then have access to our library (see screenshot below) which has both apart catalogue and operation and maintenance instructions for your machine as well as manuals for the D311 engine which your machine uses.
 [attachment=67381]Screenshot (36).png[/attachment]
Wed, Apr 13, 2022 5:28 AM
ironman3406
Chapter Twenty Seven
Send a private message to ironman3406
Hello and welcome to the club.
This appears to be a 1955 model D2. It will have a dry over center clutch. It appears to be a very well optioned tractor. PTO, Electric start Starting engine, a tool bar dozer. It appears to be a Cat Tool bar, they idea was that you can take the blade off the front and then swing the push arms to face the rear and attach rear mounted equipment to it like a ripper for example.
Here is the link to a page with some D2 information that you can find here on our website. https://www.acmoc.org/about/machines/d2
The club also has an extensive library of technical information including parts manuals, service manuals, and operation manuals. If you sign up as a member of the club you get access to all of that information with your membership.
Hope that you are able to make the purchase, D2's are a fun little tractor that are pretty easy to haul around to local tractor shows.
Have Fun!!
Nathan Duncan
Wed, Apr 13, 2022 5:39 AM
Hiranger
Reply to ironman3406:
Have Fun!!
Nathan Duncan
Thank you all for such quick responses! I will follow up with the suggestions and I think it would be good to become a member. I appreciate the advise and direction!
Wed, Apr 13, 2022 6:00 AM
Thank you received: 237
Reply to Hiranger:
Welcome Hiranger: That is one collectible CAT with all of the goodies on it. Please feel free to share your location if you like, you would be amazed at how many members may be near you and willing to assist you in person with your new catch. You are one lucky person to find such an equipped unit. Keep on posting and share photos! Thanks! JM.
Wed, Apr 13, 2022 6:39 AM
gauntjoh
Librarian
If you look on the Chapters page of the main website you will see a google map showing where members and Chapter leaders are located.
Wed, Apr 13, 2022 6:58 AM
caterpillar13
Reply to gauntjoh:
great find, see if they have the tool bar for the back of it
Wed, Apr 13, 2022 8:52 AM
Hiranger
Reply to caterpillar13:
I’ll ask about the tool bar, I’m out here on the west coast. I need to look up some local collectors-
Thanks -Hiranger
Wed, Apr 13, 2022 9:41 AM
Thank you received: 50
Reply to Hiranger:
Thanks -Hiranger
not many were fitted with a twin spool hydraulic unit most were only single spool. this means you can have not just power raise or lower but also power angle or power tilt very handy. or even a hydraulic drag ripper or other drawn implement on the rear.
dont let it get away.
Wed, Apr 13, 2022 4:44 PM
restore49
Reply to trainzkid88:
Looks like she just drove off the showroom floor.
Wed, Apr 13, 2022 8:16 PM
Hiranger
Reply to restore49:
I knew this forum would be a good source of information, I just didn’t realize how much would be shared! Thank you to all,
Sounds like I need to jump on this one-I also need to find some more info on the tool bar/ options
Hiranger-
Wed, Apr 13, 2022 9:01 PM
