Cat D2 5U75xx 2S blade group
Larry
Send a private message to Larry
Anyone have part numbers for the sealing rings on the 8F2656 piston in the hydraulic blade cylinders for this unit? Seems that a lot of parts for this old girl have been discontinued. Also the part number for the rod seal in the end of the end unit of the 5F9792 gland, preferably the newer style. On the piston rings for the hydraulic cylinder there are 6 rings to each piston, in three groups of two per piston. I don't know if these items are still available or not. Also the width of the grooves for the rings is required. Thanks in advance, Larry.
Wed, Jul 31, 2013 9:35 AM
Are you going by part numbers or casting numbers?
This is what I show for the later cylinders.
Wed, Jul 31, 2013 12:22 PM
Larry
Old Magnet, thanks for the info. Those are the cylinders. The sealing rings in mine are two per groove for a total of six per piston. I'm not too fond of that arrangement as I don't think that they seal too well. This and the fact that there was a large amount of mud in the cylinder probably accounts for the blade not staying up. The bore was not in the best shape either. However, I cleaned it up with a Sunnen cylinder hone and flushed it out with varsol. Here's hoping it helps. The previous owner's story of replacing the sealing rings does not hold up in view of what I found. Once again, Old Magnet, thanks for the info. Now I'll see if I can still get parts.Cheers, Larry.
Wed, Jul 31, 2013 8:36 PM
shovel man
Reply to Larry:
Larry,
I think these are the new Cat part numbers for the seals in the D2 cylinders they are the numbers I used to
order new seals for my D2 in 1999 !
2x 8C9133 Seal lip type
2x 3F9609 Seal ass ( I think these are rod seals)
6x 7J8879 Ring ( I think these are piston seals)
2x 3F9375 Gasket
shovel man
Thu, Aug 1, 2013 4:52 AM
Larry
Reply to shovel man:
Larry,
2x 3F9375 Gasket
shovel man
Thanks Shovel man, I will be ordering the parts tomorrow. I was concerned that the old oil type seal was insufficient but if that 8C9133 is the new type I will be installing it.Cheers, Larry.
Thu, Aug 1, 2013 8:56 AM
