Cat D2 5U Full Flow Oil Filter
Showing 1 to 6 of 6 results
ric44
Can anyone show me the correct installation of the 3 Orings that come with the replacement filter ? I know some are round and others square profile and they go on a certain way . Mine is leaking oil around the canister at the bottom and I suspect the gaskets are bad . Gonna pick up a replacement at Napa . TIA .
Sat, Nov 1, 2025 2:58 PM
Thank you received: 62
Back 20 or 30 years ago those gaskets where in the box with the filter. The last ones have not had any gaskets. But I still did not change them every filter change. But over time they harden and will leak as you are finding.
The fun part is getting the old gaskets cleaned out of the grove. The second place to use a gasket is the bottom of the canister. I believe any other gaskets would be for different applications that happen to use the same filter.
Sat, Nov 1, 2025 4:00 PM
ric44
Decided to go with a Hastings filter online after finding out the Napa stuff comes with off size gaskets . Was gonna go with original Cat filter till I found out they don't come with gaskets and they want to soak you for another 10 - 15 bucks for orings . Thanks Ray for the reply .
Sat, Nov 1, 2025 4:23 PM
Thank you received: 54
here's a tip a little grease or oring lube helps em stay in place and seat without tearing canister style filters can be a pain the arse.
i used to use stag jointing paste on our old ford 400 because the canister mounted horizontally and was real "fun" to get it to stay in place and seal.
there is only three seals one either end of the canister sleeve and one under the nut.
Sun, Nov 2, 2025 2:15 AM
ric44
Hey anyone know what size wrench I need for the engine oil drain plug ?
Tue, Nov 4, 2025 10:29 PM
Thank you received: 287
The hex head is the same size as a 3/4" bolt. You can take one and double nut it, then use a 1 1/8" wrench or socket to turn it. If you are in a real pinch, you can tap it loose with a cold chisel or even use a pipe wrench if you can get enough "bite" on the edge. Just remember to clean up any sharp edges you might create doing it "bush" style. JM
Wed, Nov 5, 2025 2:30 AM
i made my own wrench using a old nut and a old spanner. i just welded it onto the side of the old spanner.
Wed, Nov 5, 2025 7:30 AM
