cat D13000 injector nut stuck to nozzel.
Showing 1 to 10 of 16 results
phunguy1976
Send a private message to phunguy1976
Anyone have an idea how to separate a D13000 injector nozzle and nut holding it into the head? i can only turn the nut and nozzle a few degrees before nozzle fuel tube hits head bolts. i have been putting krel oil in it for weeks. Also tried heating gently. Thoughts?
Sat, Jan 30, 2021 2:19 AM
phunguy1976
FYI- this is a 1952 D8 2U
Sat, Jan 30, 2021 2:21 AM
sometimes a few raps with a soft metal drift on the retaining nut top and available flats, side on, can loosen the rust--as you can see in the scan the clearances for dirt and rust buildup are close but not usually so close as to be a great issue unless the engine bonnet had been off and or the cork gasket under the dirt cover/shield has been damaged and /or missing then it gets harder.
About the only parts available would be the cork gasket and the copper washers for the drain line banjo bolts these days.
Sun, Jan 31, 2021 7:08 AM
Reply to edb:
Raccoons will leave a nice pile of $#% on top of the injectors and really turn everything into a real rusted up mess.
Sun, Jan 31, 2021 7:46 AM
Are you working the retainer nut with the proper cut away socket? Not the chisel method I hope.
Sun, Jan 31, 2021 8:52 AM
phunguy1976
Hi-
Thanks for the reply's. I have the correct cutaway socket. I also made a conversion tool so I can use my 3/4 inch drive impact wrench. I have heated with a propane torch (fear of damage from acetylene), I have taped with a hammer and ball-peen hammer on teh flats. I have soaked in Kreil oil and I have taken off the valves and valve cover risers to allow more rotation of the injector nozzle. This allows for 2/3 of a rotation before the nozzle nipple hits the head bolts. When turned to the max I have tried using a block of wood and hammer to drive the injector nozzel down ward in hope of separating it from the nut.
I have all the parts except for a new nozzle. I am trying to replace the o-ring on the precombustion chamber since coolant is leaking out around the injector.tube and nut. I am out of ideas. Any thoughts. Thanks
Tue, Feb 2, 2021 10:25 PM
phunguy1976
Reply to phunguy1976:
Hi-
At this point I am worried I will have to pull the head in order to remove the nut and injector tube in one piece. Anything short of that would be an improvement..
Tue, Feb 2, 2021 10:30 PM
Can you post a photo of that injector nozzle?
Tue, Feb 2, 2021 10:32 PM
There is a lot of grip area between the retaining nut and the injector. May wind up having to sacrifice the injector.
Wed, Feb 3, 2021 5:22 AM
Thank you received: 19
Can you remove only the head bolts that are in the way? Even better if they're studs; you can back the entire stud out by jamming two nuts. Would that give enough room to spin 360?
Wed, Feb 3, 2021 11:28 PM
phunguy1976
Thank you Old Magnet for posting the maintenance book pic.Saved me finding it and scanning it. That is an interesting idea about removing the studs.I would have to take two out. Does anyone know if the studs are removable? Just turning the nuts to loosen the heads is a chore. I can't find a good source for the injector or i would just cut the side tube off and spin it out. Once out I feel that I could separate the injector from the nut. Anyone have a source?
Thu, Feb 4, 2021 6:57 AM
Newby Hall Tractor Fest
