CAT D13000 heads (water jacket directors)
mojo66
Send a private message to mojo66
hello, i have a 38b bucyrus dragline that came with what i believe is the first model of the d13000 power unit pre 1940s), the original heads were not made to have water jacket directors( no recessed holes for o-ring ), just the head gasket sealed the water ports, i found a good set of heads off a newer unit that use the water directors, my problem is that the water ports on the deck/block are too small for the brass water director to fit in. .. what are my options? can i bore out the water ports on the deck?... cut off the bottom part of the director?...use no directors at all and use copper coat around water ports? ( assuring i can find the right head gasket) ..thanks
Sat, May 19, 2012 6:34 AM
Thank you received: 39
Are the original heads not usable? Might try Olson's gaskets for the early head gasket. Don't recall any duscussion on counterboring the block for seals but I don't see why it could not be done.
Sun, May 20, 2012 9:14 AM
mojo66
original heads are cracked between in and out ports..alaska dont have the setup to weld them, one thing that i dont understand is if the original heads didnt come with directors and they didnt leak then why bother using directors and o-rings on the ones that call for them.. the only differance is the recessed water port in the head for the o-ring, copper coat city?
Sun, May 20, 2012 11:56 AM
Reply to mojo66:
Your leaving out the "director" part where the water circulation is aimed for more effective cooling. If your just going to seal I'd use the Permatex Super "300" Form-A-Gasket.
Sun, May 20, 2012 9:27 PM
