CAT Creep
CAT Creep
Showing 1 to 10 of 18 results
artreed
Send a private message to artreed
I had my 22 at a plow day last week. This was the first time I had had the machine in a large open area. As I crossed a large field, maybe 300yards, I had to periodically adjust direction to keep it going in a straight line. It would drift to the right about 12 to15 feet over a distance of maybe 100yards. I was not plowing at the time.
Is this indicative of anything? a clutch adjustment, or maybe oil in the clutch compartment
Any thoughts?
Thanks,
Art
Wed, May 11, 2016 9:02 AM
Is one track tighter than the other? Also check steering clutch lever free play.
Wed, May 11, 2016 9:36 AM
Time to pop some popcorn, sit back and watch the fun!
This question is sure to bring out some different opinions, but mine is that it is because of differences in internal wear in the pins and bushings of the two tracks. Could also have some little bit of slip in one steering clutch, but I think you would see that when turning under a load etc if it were happening.
Wed, May 11, 2016 10:34 AM
bruce oz
Thank you received: 23
hello , was the drawbar pinned or unpinned , type of plough ? ,bruce oz
Wed, May 11, 2016 11:04 AM
d23j
Reply to bruce oz:
Bruce , the drawbar setup would be important if he was ploughing.
Wed, May 11, 2016 1:37 PM
Wombat
Donor
Reply to d23j:
If that tractor was in Oz it would be known as a boomerang, you can hop of and have a cup of tea and wait for it to come back:biggrin1:
Wed, May 11, 2016 4:09 PM
D6 Pete
Reply to Wombat:
My 2cents worth , is "the alignment " most likely ,,, meaning ,, maybe the little tractor has done many hours plowing and turning mostly one way , round and round ,,therefore wearing one side a little more than other. ,, often you can see the trouble , mostly if the distance from track to radiator is a little different from other side ,, if you know what I mean !!! .. then again ,,, I could be wrong ,, on your machine !! ,,,without seeing it .. ! .. Regards pete
Wed, May 11, 2016 4:48 PM
d9gdon
Reply to D6 Pete:
Check for a bad bottom roller or idler problem or if the UC is worn more on the slow side. The bushings may be hitting the bottom rollers.
Wed, May 11, 2016 7:01 PM
old-iron-habit
Reply to d9gdon:
Curvature of the earth. In between the spring equinox and the longest daylight day the gravitional side pull is the greatest. In the fall it should pull the other way. :lie::lie::lie::lie:
Or as an alternate; I think wear is a bit more pronounced on one side. It would not take much. I've seen the same thing many times when traveling straight for a distance.
Thu, May 12, 2016 3:40 AM
Reply to old-iron-habit:
I'll bet it was the wind!
Thu, May 12, 2016 4:22 AM
d23j
If this was down under, it could be heading of to where the good looking lady's are. I have been in friends cars and they always head to where the girls are!
Thu, May 12, 2016 6:05 AM
