CAT-CAVE Order to Cat INC Inlet Manifolds for Restoration CAT USA HQ Projects
Showing 1 to 10 of 26 results
Catman
Send a private message to Catman
  [attachment=73180]Cat Inlet Manifold (2).jpg[/attachment][attachment=73181]Cat Inlet Manifold (3).jpg[/attachment][attachment=73182]Cat Inlet Manifold (1).jpg[/attachment]
If Any ACMOC Member.s...   Needs any Cat-Cave  Parts .. Send a message back to myself..  Plentry on Stock To SHIP Out from Cat-CAVE HQ !..
CATMAN BUSY  HAS   CAN  BEE ATM..  Helping  BEST  I CAN .. .
Doing  My BEST  to Help ACMOC Members with Cat-Cave Parts  ATM.   [attachment=73182]Cat Inlet Manifold (1).jpg[/attachment] [attachment=73180]Cat Inlet Manifold (2).jpg[/attachment] [attachment=73181]Cat Inlet Manifold (3).jpg[/attachment]
CM
www.cat-cave.com
Tue, Aug 8, 2023 6:32 AM
Wow! You men are Masters!
Tue, Aug 8, 2023 8:35 AM
Thank you received: 54
casting your self or getting them done? thats the expensive and difficult bit is making the patterns for the moulds.
Tue, Aug 8, 2023 4:20 PM
Catman
We made our Own New Patterns to Blue Prints. Then Myself in the foundry. Making Cores and Moulding and Assembly Including lots of drilling to vent etc.
Making the Patterns is the EASY part. Trying to get the Hot Metal to RUN and fill the Double Cored Area is the HARD Part. Down to Critical TEMP of Metal and Pre Heat Burn Out of the Mould before the Pour. using a chimney system to help DRAWN the Hot Metal.
CM
 [attachment=73185]Patterns (1).jpg[/attachment]  [attachment=73186]Patterns (2).jpg[/attachment]  [attachment=73187]Patterns (3).jpg[/attachment]  [attachment=73188]Patterns (4).jpg[/attachment]
www.cat-cave.com
Tue, Aug 8, 2023 6:24 PM
Catman
Myself. at work in the Sand Pit. Apologies for Photo Imagine Quality. But Bear in mind after spending 8 hours working inside this Environment. A Good shower is needed.
CM
 [attachment=73189]Catman at work (1).jpg[/attachment]  [attachment=73191]Catman at work (2).jpg[/attachment]  [attachment=73190]Catman at work (3).jpg[/attachment]
www.cat-cave.com
Tue, Aug 8, 2023 6:38 PM
Catman
Those Photos above are for CAT 20 L / 20 PL.Inlet Manifold.
These Photos below show the CAT GAS 35 Inlet Manifold being Assembled.
CM
 [attachment=73193]GAS 35 INLET 1.JPG[/attachment]  [attachment=73195]GAS 35 INLET 2.JPG[/attachment]  [attachment=73192]GAS 35 INLET 3.JPG[/attachment]  [attachment=73194]GAS 35 INLET 4.JPG[/attachment]
www.cat-cave.com
Tue, Aug 8, 2023 7:25 PM
Catman
Need to Add Weight on Top of the Moulds to Stop the Hot metal from Lifting the Top Half.
CM
 [attachment=73196]The Pour 1.jpg[/attachment]  [attachment=73198]The Pour 2.jpg[/attachment]  [attachment=73200]The Pour 3.jpg[/attachment]  [attachment=73199]The Pour 4.jpg[/attachment]  [attachment=73197]The Pour 5.jpg[/attachment]
www.cat-cave.com
Tue, Aug 8, 2023 7:29 PM
Catman
In the Photo above, Thats Myself using a wooden stick after pouring Spirt down the Vents and Igniting them with my stick on fire . Note at Arms length. Thats as Close to molten metal you will find me.With One Ton of Molten Iron in that Crucible hanging from the overhead crane straight from the furnace manifolds are Pour No 2,3,4. We need the Higher Temp and a PURE Metal Fill. Hence the 1st pouring will always have some small impurities on the Top.
Back to Working with WOOD and a Shrink Rule LOL CAT 8C20 Heatbox
CM
 [attachment=73202]8C20 Heatbox Patterns (1).jpg[/attachment]  [attachment=73201]8C20 Heatbox Patterns (2).jpg[/attachment]
www.cat-cave.com
Tue, Aug 8, 2023 8:09 PM
Catman
The morning after the Pour. Using the overhead crane and chains to remove the weights and steel girders. Out of the Sand Pit to the Knock Out Area. Yeap using a Sledge Hammer to remove the Sand to Find the Raw Casting. Then using a Small hammer. Hammer the Casting to break up the sand inside the core jacket and Poke about inside the Core Holes to get sand out. Then Load into Shot Blaster. Fettling Up with a Grinder then Machining Up. Followed by a Pressure Test on the inner core to check ALL GOOD. High Temp Alu Foundry Furnace Coating. Box up.
CM
 [attachment=73203] Big Hammer (1).jpg[/attachment]  [attachment=73204] Big Hammer (2).jpg[/attachment]  [attachment=73205] Big Hammer (3).jpg[/attachment]
www.cat-cave.com
Tue, Aug 8, 2023 8:48 PM
chuckb
Reply to Catman:
CM
Cat Cave castings are the Best quality ever pattern making is truly painstaking work my dad was a pattern maker and he would talk about his workto be able to make the pattern for the mold and have to size it for the shrink of the molten iron his work was always to plus or minus one thousandth of an inch he would hand sand the piece by hand
Wed, Aug 9, 2023 12:09 AM
Catman
Reply to chuckb:
chuckb. THANK YOU Sir. Smile. Your CAT GAS R5 Manifold Complete System from Cat Cave Meeting Cat Inc Approval was Good enough for myself. But Now with Comments from yourself . Saying Cat Cave castings are the Best quality. From CHUCKB Himself. SMILE Really does mean a LOT. Cheers You Know all about the Cat Cave Castings Project History..
chuckb. Snr Catman really enjoys when you Ring him for a chat on the Phone. You need to Phone Catman Snr ASAP. Regarding your Idea of Cat Cave Re-Manufacturing the three different Versions of the BEST 60 thou to CAT 60 Manifold systems. If you Generate Enough Interest for a Batch Run. Like 48 off each part. All Interchangeable back to Blue Prints. Simple Parts to RE-MAKE. Only the Bigger Brother to the Cat 30 Manifold System. Hence EASY to Cast Up being a Larger Manifold System. Hence more SPACE inside the Cavity Jacket... Cat Cave can Re-Manufacture Them.
Thanks CM
www.cat-cave.com
Wed, Aug 9, 2023 4:16 AM
| Kingaroy, Queensland
