CAT Bolt Cross-reference chart
bernie
Hey,
I am looking for a chart that will cross from CAT part number of bolts, nuts, washers etc. to specific, "over the counter" sizes.
Any thoughts?
bernie
Fri, Sep 26, 2008 9:49 AM
Jack
The Cat dealers from time to time put out a flier catalogue called ONE SAFE SOURCE. It gives all the dimensions of all the current Cat part number bolts, including the grip length & head height. I keep a copy handy in the shop for the opposite reason: When a hardware store bolt fails I can usually find a high quality replacment of the same size at Cat. True, it's not the only source of good grade 8 bolts, but it's the handy one around here.
Fri, Sep 26, 2008 10:08 AM
bernie
Reply to Jack:
I found some info...
http://www.cat.com/cda/files/87031/7/hardwre.pdf
http://www.cat.com/cda/layout?m=37648&x=7
Fri, Sep 26, 2008 11:55 AM
